| bajafreaks |
Oct 15 2026, 10:24 AM
Member ![]() ![]() Group: Members Posts: 177 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
I'm in the middle of installing a new master cylinder, and yes its the job from hell.
My plastic reservoir lines are pretty brittle so I'm thinking I may replace them with rubber lines instead that are approved for brake fluid of course, it will probably make the overall MC install easier as well, at least I hope so. Anyone replaced their lines with all rubber? The size I believe is 9mm inside diameter, I'm finding 3/8" which 9.5mm. |
| Literati914 |
Oct 15 2026, 03:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,392 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm pretty sure you had a thread about your M/C, can't remember what it was. I think you were looking for the metal ends. Do I have a point, why yes, if you never found the metal ends and you still need I have two I no longer will be using. I provided the needed end to the guy that was looking… I asked him for details on what he’d be using for the tubing - got no reply. Maybe if @barkamatic sees this thread, he’ll share? |
bajafreaks master cylinder reservoir lines Oct 15 2026, 10:24 AM
bdstone914
I'm in the middle of installing a new master ... Oct 15 2026, 10:41 AM
Literati914 :popcorn: Oct 15 2026, 11:01 AM
emerygt350 is your difficulty getting the grommets back into ... Oct 15 2026, 11:11 AM
bajafreaks
is your difficulty getting the grommets back into... Oct 15 2026, 01:12 PM
fiacra
is your difficulty getting the grommets back int... Oct 15 2026, 01:38 PM
bajafreaks
[quote name='bajafreaks' post='3275255' date='Oct... Oct 15 2026, 02:04 PM
Shivers
I'm in the middle of installing a new master ... Oct 15 2026, 12:04 PM
bajafreaks
[quote name='bajafreaks' post='3275240' date='Oct... Oct 15 2026, 01:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th October 2026 - 05:41 PM |
