| ConeDodger |
Oct 15 2026, 09:55 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,613 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
Maybe Marty can weigh in on this. The 3.0 liter twin turbo motor in my Macan GTS is so freaking amazing, I wonder if it would fit in a 914? (IMG:style_emoticons/default/confused24.gif)
| tygaboy |
Oct 15 2026, 11:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,859 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
I looked into this and went so far as separating the starter ring gear from a Macan flywheel. Talked with Kennedy about an adapter. The issue is you need to convert the engine to dry sump as the Macan sump is quite deep. I even talked with Marty about his set up.
As @SirAndy points out, it's doable, but I opted for something simpler... (IMG:style_emoticons/default/happy11.gif) If you decide to go this way, let me know. I have a ring gear I don't need. |
ConeDodger Macan GTS motor in a 914? Oct 15 2026, 09:55 PM
SirAndy Anything will fit. All it takes is money.
Having ... Oct 15 2026, 10:56 PM
Maltese Falcon Only 3) things needed; Torch, Hammer, Machine shop... Oct 16 2026, 02:25 AM
Maltese Falcon Aluminum adapter plate is approx 1" thick, wh... Oct 16 2026, 02:32 AM
Maltese Falcon You can source a good clutch pressure plate combo ... Oct 16 2026, 02:39 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th October 2026 - 04:27 AM |
