| robkammer |
Oct 6 2026, 09:05 AM
Robbo ![]() ![]() Group: Members Posts: 301 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
Hello brain trust! The engine saga continues on our BB. What started in February as an engine reseal, head refresh, and engine compartment repair is still ongoing. The heads needed a full refresh, and close inspection found cracks, that the head expert 'fixed' with Timeserts. Lifter wear pointed to a cam lobe that was half gone. So off the short block went to a very well know Type I and IV engine builder. Wife and I went to Florida and wandered around for a month while this was all taking place. Back to Ohio in March and I started gathering the parts needed for the re-install.
The heads came back looking great, and the short block looked even better, now with fresh bearings, a stock cam and bearings, and a new oil pump.Oh, and we dicovered that I had a 2056, Cool, right? Got the heads on, all of the tin, wiring and hoses. Put the beast in the car and started the break in process. First 30 miles, then oil change and valve adjust, then 100 more, rinse and repeat. Noticed a pretty significant oil leak coming from the front of the engine. it was the new oil pump, totally unacceptable. The builder came to my shop in hope that the oil cover gasket was the problem. Uh, no. So out came the motor, back to the builder who is 100 miles away. At the 130 mile mark I also pulled the plugs to see how they were firing. All good, except that three of the Timeserts came out with the plugs, crap. So while the engine was at the builder I ordered a new set of AMC heads, shipped directly to the builder. Why not, eh? Get the engine back in with the new heads, start the process again. Got through about 65 miles and the engine is running like crap. All of the FI bits are working as they should, and all with engine wires are Jeff b's harnesses. The only non functioning bit is the thermo sensor on the side of the plenum. Plugs looked ok but maybe a bit on the lean side. Time for a Smoke test! Cool tool for sure, brings back memories of my Lionel trains. At first glance it looked like the throttle body shaft was leaking, although I had Rocky in Walla Walla rebuild it while the engine was out the second time. Nope, turns out that one of the two unused tubes through the plenum had somehow come loose and is allowing atmosphere into the plenum. I've attached a video. So after that long intro about my sorrows, the question is: Can I remove the plenum while the engine is in the car? I struggled getting the intake runners onto the plenum the second time while the engine was on the cart, I used the 100 mile old rubber tubes and they may have shrunk. I'll buy new rubbers again, and of course the intake gaskets. But am I delusional that I may be able to get the plenum off in order to repair or replace it without dropping the engine, Again!!?? Any helpful advice will truly be appreciated. Robbo
smokin.MOV ( 3.06mb )
Number of downloads: 51 |
| Jack Standz |
Oct 20 2026, 12:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 966 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Hi Fellas: I do not have a CHT gauge, nor an AFR gauge. Or a fuel pressure gauge either. This engine has been a 2056 since way before I bought it in 21. Ran fine, not lean for the thousands of miles I've driven it. At full temp yesterday it settled into a nice idle once I adjusted the idle screw on the TB. I want to check the timing again just to be sure, Does the CHT control anything other than the AAR? And what would an AFR tell me? "Ran fine, not lean for the thousands of miles I've driven it." How do you know this? How do you know if it's not running lean? (Yes, there are ways, but just curious how you know). Also, not saying that you are incorrect, but would suggest (like Emery said) an AFR gauge will tell you if/when you are running lean or rich. And a CHT gauge will give you the information you need to prevent damaging those heads from overheating. Many 914 owners run without an AFR gauge and/or a CHT gauge. However, running a modified Type IV motor (even a 2056) changes how your motor performs and what it needs to live a long life. Until you get it running right, keep an eye on head temps and your fuel/air mixture. |
robkammer 2.0 plenum issue Oct 6 2026, 09:05 AM
emerygt350
Hello brain trust! The engine saga continues ... Oct 6 2026, 09:24 AM
robkammer I need to fix that leak before going much further... Oct 6 2026, 10:13 AM
JamesM Sounds like a bit of an ordeal for sure
Noticed... Oct 6 2026, 10:47 AM
dax1969
Noticed a pretty significant oil leak coming from... Oct 7 2026, 03:26 AM
Superhawk996
Noticed a pretty significant oil leak coming fro... Oct 7 2026, 06:05 AM
JamesM
So while the engine was at the builder I ordered... Oct 6 2026, 10:54 AM
robkammer Hey Teeners, thanks for all of the replies. A coup... Oct 6 2026, 04:08 PM
emerygt350 Just put a plain Jane fuel pressure gauge inline w... Oct 6 2026, 06:15 PM
robkammer Thanks Emory: Yes, stock ignition. Not going anywh... Oct 6 2026, 07:16 PM
emerygt350
Thanks Emory: Yes, stock ignition. Not going anyw... Oct 7 2026, 05:53 AM
robkammer Hey fellas, here’s an update. I have the plenum ... Oct 14 2026, 04:38 PM
emerygt350 Don't worry too much about the TPS. Just make... Oct 14 2026, 06:50 PM
robkammer Sounds simple, I guess my question is: How can I t... Oct 15 2026, 04:28 AM
emerygt350 The wire closest to the passenger side is the idle... Oct 15 2026, 05:49 AM
robkammer Perfect! Thanks for the explanation. Plenum an... Oct 16 2026, 08:09 AM
robkammer Hey teeners, here’s the latest update; It runs... Oct 19 2026, 06:12 PM
Jack Standz
[quote name='dax1969' post='3274415' date='Oct 7 ... Oct 19 2026, 08:37 PM
Superhawk996 Thanks for sharing that supplier. Hadn’t seen t... Oct 19 2026, 09:56 PM
Jack Standz
Hey teeners, here’s the latest update; It runs... Oct 19 2026, 08:50 PM
robkammer Hi Fellas: I do not have a CHT gauge, nor an AFR g... Oct 20 2026, 07:43 AM
emerygt350
Hi Fellas: I do not have a CHT gauge, nor an AFR ... Oct 20 2026, 11:51 AM
robkammer Thanks. I typically pull the plugs at each oil int... Oct 20 2026, 01:12 PM
emerygt350
Thanks. I typically pull the plugs at each oil in... Oct 20 2026, 02:10 PM
robkammer
Thanks. I typically pull the plugs at each oil i... Oct 20 2026, 04:29 PM
robkammer
Thanks. I typically pull the plugs at each oil i... Oct 20 2026, 04:31 PM
rjames
Thanks. I typically pull the plugs at each oil in... Oct 20 2026, 04:55 PM
Jack Standz
[quote name='emerygt350' post='3275762' date='Oct... Oct 20 2026, 04:57 PM
emerygt350 I am about 6 hours from you, otherwise I would lov... Oct 20 2026, 07:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 04:25 AM |
