| RKramden |
Oct 19 2026, 09:50 AM
Member ![]() ![]() Group: Members Posts: 53 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
I think I know the general response, but I’ll ask anyway.
Putting a 3.0 performance built (premium pump gas) into the 914. No intention of racing. Maybe an auto cross or track night, or terrorize the neighborhood, but mostly C&C and PCA events. No heat exchangers ( So.Cal), an oversized oil tank in the engine bay, and a 916-6 type engine lid. In lieu of a remote oil cooler I was considering changing the fresh air fan piping to blow back through the heater longs up through the tins and outlet right next to the engine cooling fan inlet space. Or possibly just blow on either side of motor below the tins. I’m wondering if this has ever been done successfully or if the idea makes any sense at all? Any thoughts or suggestions would be appreciated |
| RKramden |
Oct 22 2026, 07:07 PM
Thank you all for your inputs. Ill be adding a remote cooler. Any thoughts on the oil tank size? Will the oversized PMB in fender model be enough or do I need more capacity?
RKramden 3.0 cooling option Oct 19 2026, 09:50 AM
brant The heater fan is really an insignificant amount o... Oct 19 2026, 10:04 AM
mepstein The fresh air fan hardly moves any air in the cabi... Oct 19 2026, 10:06 AM
Superhawk996 :agree: both the above are correct
You cannot of... Oct 19 2026, 12:32 PM
IronHillRestorations You won’t get enough airflow from the fresh air ... Oct 20 2026, 07:29 AM
mepstein Do the conversion, drive it. If it needs more cool... Oct 20 2026, 09:58 AM
Superhawk996
Sometimes it’s better to have a running car th... Oct 20 2026, 10:42 AM
JmuRiz
Sometimes it’s better to have a running car tha... Oct 20 2026, 02:50 PM
worn
Sometimes it’s better to have a running car th... Nov 3 2026, 11:30 PM
pete-stevers My recommendation split for the external cooler up... Oct 20 2026, 02:39 PM
Cairo94507 A 3.0 in southern CA is likely going to need an ex... Oct 20 2026, 03:52 PM
mb911 Build it first get it running add a cooler in the ... Oct 20 2026, 07:48 PM
Steve
Build it first get it running add a cooler in the... Oct 21 2026, 08:00 AM
mepstein Oil tank - Definitely Ben’s/MB911/914-6Werkshop.... Oct 22 2026, 07:25 PM
RKramden Based on my usage noted at the beginning of this t... Nov 2 2026, 05:47 PM
930cabman
Based on my usage noted at the beginning of this ... Nov 2 2026, 05:51 PM
mb911
Based on my usage noted at the beginning of this ... Nov 3 2026, 08:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 07:08 AM |
