| young55961 |
Jun 18 2026, 02:34 PM
Member ![]() ![]() Group: Members Posts: 53 Joined: 15-March 18 From: Arcadia Member No.: 21,972 Region Association: Southern California |
I have a question about the ECU wiring harness.
There are three pairs of white wires with female spade terminals on the harness. I believe they are the ground wires for the fuel injectors, but I can't find where they are supposed to connect. Should these wires be connected to the negative (-) terminal of the ignition coil? If anyone has a photo showing the correct connection, I would really appreciate it. Thank you! |
| Dave_Darling |
Nov 1 2026, 07:04 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,365 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I'm pretty sure that #31 should get grounded by the ECU when it sees that the engine is rotating. It does not get a full-time ground.
--DD |
young55961 Convert back to D Jet Fuel Injection- Jun 18 2026, 02:34 PM
brant There was supposed to be a three prong connector o... Jun 18 2026, 02:46 PM
JeffBowlsby 2 of the three pairs are injector grounds. The th... Jun 18 2026, 02:46 PM
young55961
2 of the three pairs are injector grounds. The t... Jun 18 2026, 02:52 PM
Ishley Here is what you’re looking for in the yellow ci... Jun 18 2026, 08:12 PM
young55961
Here is what you’re looking for in the yellow c... Jun 19 2026, 10:54 AM
DC_neun_vierzehn
Here is what you’re looking for in the yellow c... Jun 19 2026, 03:54 PM
young55961
[quote name='Ishley' post='3261972' date='Jun 18 ... Jun 19 2026, 08:17 PM
Jack Standz It's easy enough to get one. Here's one e... Jun 19 2026, 03:44 PM
Ishley Mine is a '72 1.7 that I rebuilt into a 2056. ... Jun 19 2026, 04:25 PM
Dave_Darling Mine is further back, right by the flywheel end of... Jun 19 2026, 09:27 PM
DC_neun_vierzehn
Mine is further back, right by the flywheel end o... Jun 22 2026, 05:27 AM
robkammer Mine is right at the top of the case split at the ... Jun 23 2026, 05:38 AM
friethmiller :popcorn:
Observing... learning. I'll be do... Jun 23 2026, 07:33 AM
young55961 I'm trying to test-run my 1975 Porsche 914 2.0... Nov 1 2026, 12:22 PM
GregAmy From my Microsquirt build notes.
T4-I
.75 and .5m... Nov 1 2026, 12:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 09:18 PM |
