| DavidSweden |
Oct 31 2026, 03:56 PM
Member ![]() ![]() Group: Members Posts: 486 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Hello,
Could do with some advice from the D-Jet experts. I’ve fitted AA big-bore cylinders and pistons to my 2.0 914. It’s still running D-Jet and actually runs really well, but I’m worried it might be running a bit lean with the extra capacity. I’ve fitted a wideband lambda sensor, so what sort of readings should I be seeing at idle, normal cruise and under full load? I haven’t touched the fuel pressure since fitting the big-bore kit. Should I increase it, and if so, what pressure should I be aiming for? Thanks in advance |
| VaccaRabite |
Nov 2 2026, 10:57 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,946 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
You are now a custom engine owner. Congrats! Now get a good, temp compensated CHT gauge. Put the lead under the spark plug on cyl.3 - the hottest point on the engine under normal circumstances. You will need to file a small groove for the wire in the head, its not a big deal. I'm unsure what "big bore" means to you - probably a 2056 if you were starting with a 2.0. USUALLY you need to adjust the MPS for the slight bump in displacement. There are many guides here on World about it. But I'm way more concerned about CHTs then what my wideband says. And you will adjust both by tuning the MPS. Zach |
DavidSweden Am I running lean? Oct 31 2026, 03:56 PM
emerygt350 Do you have a head temp gauge installed? That is ... Oct 31 2026, 05:40 PM
DavidSweden Thanks for the feedback,
Yes, it's a 2056. I ... Nov 2 2026, 05:09 PM
emerygt350 I think adding pressure is better than nothing (an... Nov 2 2026, 07:27 PM
FlacaProductions @emerygt350 - what's the $30 tool?! Nov 3 2026, 10:49 AM
emerygt350
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 3 2026, 11:30 AM
FlacaProductions ah yes - LCR - I spent a lot more on my LCR but it... Nov 3 2026, 02:22 PM
emerygt350
ah yes - LCR - I spent a lot more on my LCR but i... Nov 4 2026, 07:34 AM
FlacaProductions Great points. Nov 4 2026, 09:36 AM
Superhawk996 Going back to the original question
“I’ve fi... Nov 4 2026, 10:10 AM
mgphoto Old school check, run the engine at top speed for ... Nov 4 2026, 12:59 PM
emerygt350 I would say that works well but the more I poke at... Nov 4 2026, 01:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 12:15 AM |
