| DavidSweden |
Oct 31 2026, 03:56 PM
Member ![]() ![]() Group: Members Posts: 486 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Hello,
Could do with some advice from the D-Jet experts. I’ve fitted AA big-bore cylinders and pistons to my 2.0 914. It’s still running D-Jet and actually runs really well, but I’m worried it might be running a bit lean with the extra capacity. I’ve fitted a wideband lambda sensor, so what sort of readings should I be seeing at idle, normal cruise and under full load? I haven’t touched the fuel pressure since fitting the big-bore kit. Should I increase it, and if so, what pressure should I be aiming for? Thanks in advance |
| FlacaProductions |
Nov 3 2026, 10:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
@emerygt350 - what's the $30 tool?!
| emerygt350 |
Nov 3 2026, 11:30 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,835 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
DavidSweden Am I running lean? Oct 31 2026, 03:56 PM
emerygt350 Do you have a head temp gauge installed? That is ... Oct 31 2026, 05:40 PM
VaccaRabite :agree:
You are now a custom engine owner. Congr... Nov 2 2026, 10:57 AM
DavidSweden Thanks for the feedback,
Yes, it's a 2056. I ... Nov 2 2026, 05:09 PM
emerygt350 I think adding pressure is better than nothing (an... Nov 2 2026, 07:27 PM
FlacaProductions ah yes - LCR - I spent a lot more on my LCR but it... Nov 3 2026, 02:22 PM
emerygt350
ah yes - LCR - I spent a lot more on my LCR but i... Nov 4 2026, 07:34 AM
FlacaProductions Great points. Nov 4 2026, 09:36 AM
Superhawk996 Going back to the original question
“I’ve fi... Nov 4 2026, 10:10 AM
mgphoto Old school check, run the engine at top speed for ... Nov 4 2026, 12:59 PM
emerygt350 I would say that works well but the more I poke at... Nov 4 2026, 01:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 12:15 AM |
