> Oil tank removal- stay stock or go aluminum?
peteinjp
post Nov 3 2026, 05:13 AM
I have the rear trailing arm off for replacement and looking at the oil tank.... the paint job was obviously not up for the task. The car only has a 4000 miles since this was installed new. Everything on this car (snoopy) was done with new and or original style parts so from a visual perspective it all looks original. But I just can't see how the steel tank wouldn't be better if it was aluminum. The filler neck is also a reproduction part and has tons of rust from condensation- surprising considering how much this stuff costs!
So- I'm on the fence- pull what I have and send it out for some type of 2 part epoxy treatment and get the filler neck cad plated, do my best with a wire brush and use some quality rubberized spray (not great for heat transfer- if that matters) or sell it and go all aluminum.
Also seems like a good idea to get the chrome trim back on with the tank out....
Pete
peteinjp
post Nov 3 2026, 06:07 PM
Lots of great feedback. I'm not really into adapters so I wrote Ben to see if he if metric is a possibility or not.
Leaning towards the aluminum tank for now and properly restoring the repro tank. I have to avoid mission creep. Right now the goal is to replace the dented trailing arm, get the re-restored PMB calipers on and get the brake system closed.
Or I could leave the tank in and wait for phase 2 of the re-restoration where I drop the engine and address all the hard to reach areas, fix all the leaks, adjust teh valves, replace the flywheel and pressure plate etc etc. - that will probably be in a years time.
Right now I just want to see the car back on the road because sitting around is the worst thing possible for all the systems- including the MFI.
Is having the trailing arm off way easier in terms of getting the tank in and out?? It sure seems like it would be.
Thx!
P
- Lo-Fi Version Time is now: 24th November 2026 - 01:06 PM
