| DavidSweden |
Oct 31 2026, 03:56 PM
Member ![]() ![]() Group: Members Posts: 486 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Hello,
Could do with some advice from the D-Jet experts. I’ve fitted AA big-bore cylinders and pistons to my 2.0 914. It’s still running D-Jet and actually runs really well, but I’m worried it might be running a bit lean with the extra capacity. I’ve fitted a wideband lambda sensor, so what sort of readings should I be seeing at idle, normal cruise and under full load? I haven’t touched the fuel pressure since fitting the big-bore kit. Should I increase it, and if so, what pressure should I be aiming for? Thanks in advance |
| FlacaProductions |
Nov 3 2026, 02:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
ah yes - LCR - I spent a lot more on my LCR but it's good to know that option is out there! and yes - that's the key to setting/re-setting the MPS.
| emerygt350 |
Nov 4 2026, 07:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,835 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
ah yes - LCR - I spent a lot more on my LCR but it's good to know that option is out there! and yes - that's the key to setting/re-setting the MPS. I wouldn't try to 'set' an MPS with this one, but you can definitely see where your MPS reads currently and return it to those settings after you mess around. Whenever I pull mine I establish the existing curve on paper and then start fiddling. Looking at the values and descriptions from pbanders about replicability among MPSs makes me think even an expensive version isn't really going to let you set it and not tune it on the car. Hard to know what the correct values are for something so analog being measured by something so affected by the tool being used. Always make sure you have a fresh battery in the LCR as well. Makes a big difference. |
DavidSweden Am I running lean? Oct 31 2026, 03:56 PM
emerygt350 Do you have a head temp gauge installed? That is ... Oct 31 2026, 05:40 PM
VaccaRabite :agree:
You are now a custom engine owner. Congr... Nov 2 2026, 10:57 AM
DavidSweden Thanks for the feedback,
Yes, it's a 2056. I ... Nov 2 2026, 05:09 PM
emerygt350 I think adding pressure is better than nothing (an... Nov 2 2026, 07:27 PM
FlacaProductions @emerygt350 - what's the $30 tool?! Nov 3 2026, 10:49 AM
emerygt350
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 3 2026, 11:30 AM
FlacaProductions Great points. Nov 4 2026, 09:36 AM
Superhawk996 Going back to the original question
“I’ve fi... Nov 4 2026, 10:10 AM
mgphoto Old school check, run the engine at top speed for ... Nov 4 2026, 12:59 PM
emerygt350 I would say that works well but the more I poke at... Nov 4 2026, 01:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 12:15 AM |
