> Am I running lean?
DavidSweden
post Oct 31 2026, 03:56 PM
Hello,
Could do with some advice from the D-Jet experts.
I’ve fitted AA big-bore cylinders and pistons to my 2.0 914. It’s still running D-Jet and actually runs really well, but I’m worried it might be running a bit lean with the extra capacity.
I’ve fitted a wideband lambda sensor, so what sort of readings should I be seeing at idle, normal cruise and under full load?
I haven’t touched the fuel pressure since fitting the big-bore kit. Should I increase it, and if so, what pressure should I be aiming for?
Thanks in advance
mgphoto
post Nov 4 2026, 12:59 PM
"If there is a mistake it will find me"
Old school check, run the engine at top speed for a minute, throw the clutch, turn the engine off, coast to a stop, pull the plugs, tan color means running great, white is hot, lean, black is rich.
- Lo-Fi Version Time is now: 23rd November 2026 - 12:15 AM
