> Sloppy fit from the factory?, Engine Cooling Flaps
Literati914
post Nov 4 2026, 03:14 PM
So is the engine cooling flap that’s on the Driver’s side (L) just a sloppy fit when the engine is warm/hot and the thermostat is expanded? The pics below are representing my engine in that state and you can see a gap at the bottom and outside edge.
The passenger flap (not pictured) is sitting solidly covering the oil cooler with no gap under it (as should be). And as you can see from the picture, this side can not “close” anymore than it is, because it fouls the small vertical tin in front of cylinder 2. So maybe what I’m seeing is an engineered gap ??
Correct for the driver’s side or no?
Literati914
post Nov 4 2026, 03:51 PM
Here a shot from the fan shroud side looking towards cyl #2 and there’s even a gap there too, highlighted by the screwdriver.
porschetub
post Nov 4 2026, 05:13 PM
QUOTE(Literati914 @ Nov 5 2026, 10:51 AM) *
I had one similar on my last build,new pivot bushing but it never lined up ,turned out it was bent ??? had a spare and it was spot on ,not seen this issue before ...worth checking IMO ,good luck,cheers.
7 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th November 2026 - 06:55 PM
