| Literati914 |
Nov 4 2026, 03:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,408 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
So is the engine cooling flap that’s on the Driver’s side (L) just a sloppy fit when the engine is warm/hot and the thermostat is expanded? The pics below are representing my engine in that state and you can see a gap at the bottom and outside edge.
The passenger flap (not pictured) is sitting solidly covering the oil cooler with no gap under it (as should be). And as you can see from the picture, this side can not “close” anymore than it is, because it fouls the small vertical tin in front of cylinder 2. So maybe what I’m seeing is an engineered gap ?? Correct for the driver’s side or no? Attached thumbnail(s) |
| Superhawk996 |
Nov 4 2026, 07:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,159 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Tin is sitting too high. It’s either bent or something is pushing it up.
Literati914 Sloppy fit from the factory? Nov 4 2026, 03:14 PM
Literati914 Here a shot from the fan shroud side looking towar... Nov 4 2026, 03:51 PM
porschetub
Here a shot from the fan shroud side looking towa... Nov 4 2026, 05:13 PM
mgphoto I’ve found 2 engines that had this flap glued cl... Nov 4 2026, 05:58 PM
Superhawk996 Not correct Nov 4 2026, 06:42 PM
Literati914 The cooling flap is definitely not bent.. the smal... Nov 4 2026, 06:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 07:23 PM |
