> 123 ignition and tach question, How do I set up tach to work with 123 ignition
pete-stevers
post Nov 6 2026, 01:01 PM
Shinee Side Up
I have a 123 ignition on my 2.4 six motor but I am not sure how to set up my tach to work with the ignition.. can I use a 914 tach? What else do I need?
pete-stevers
post Nov 6 2026, 01:39 PM
Shinee Side Up
Does the 123 dizzy have enough current to power the 914 tach
or will I need a six tach.. I hope not
the motor is a 2.4 t 1973.5
the tach is a stock 914 4 1974
VaccaRabite
post Nov 6 2026, 02:11 PM
En Garde!
QUOTE(pete-stevers @ Nov 6 2026, 02:39 PM) *
The Dizzy does not power the tach. The coil does.
The tach reads the pulses from the coil divided by the number of engine cylinders and determines the speed of the engine.
Where it matters is that the tach needs to be able to interpret the pulses from the coil to get to the right RPM. I don't know that a /4 tach can do that for a /6 engine. Usually there is a switch on the back of the tach to determine if the engine is 4/6/8 cylinders. On a stock tach, I bet you have to change it for a /6 or go aftermarket. But I could be wrong if there is a switch on the back that I have just never looked for.
But, again, the dizzy is not in the chat for this. Its all the coil.
Zach
6 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
1 Members: chmillman
- Lo-Fi Version Time is now: 6th November 2026 - 02:26 PM
