| Literati914 |
Nov 6 2026, 08:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,413 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
The 1.7L car I’m working on had a single carb set up on it when I got it, which I removed to clean engine, replace some seals and paint the tin. I was a little surprised that the intake runners had none of the phenolic blocks at the head area. There were only thin aluminum gaskets there - 4, one at each port. I want to verify that the stock “blocks” removal is correct and that the individual thin aluminum gaskets are the best option. There’s probably not any difference but I was considering these ones below, thoughts?
Also I have a partially complete 1.7 D-jet system, maybe I should bite the bullet and get it up and going instead.. but I figure the single carb will probably get the car running sooner and keep me motivated to mess with that later. Here’s the gaskets, they’ll work, right? https://a.co/d/04zbW7Cv . |
| dtmehall |
Nov 6 2026, 09:12 PM
Member ![]() ![]() Group: Members Posts: 398 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
Literati914 Intake Gaskets for Single Carb Setup Nov 6 2026, 08:25 PM
Superhawk996 With single carb you actually want heat to get int... Nov 6 2026, 09:06 PM
Literati914
thanks Superhawk996
:beer2:
Yes thanks, appre... Nov 6 2026, 10:43 PM
Literati914
With single carb you actually want heat to get in... Nov 6 2026, 10:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th November 2026 - 02:48 AM |
