| andrewvolsen |
Nov 9 2026, 01:06 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
I am working on rebuilding the carbs and tuning the engine in my '74. What I know (or was told) about it:
From what I've gathered reading other carb and ignition tuning threads on this forum, the 009 is not considered a good distributor for this engine. I have a big box of stock 914 distributors to choose from - which one would be a good choice? |
| andrewvolsen |
Nov 9 2026, 09:28 PM
I have these distributors in a box, in varying conditions:
REPRO 009s 0 231 178 009 (2X) 0 231 167 070 / 113 905 205 AH 0 231 174 009 / 039 905 205 0 231 172 019 / 022 905 205 P 0 231 181 009 / 022 905 205 AA 0 231 174 005 / 113 905 205 F (3X) 0 231 124 021 / 039 905 205 B 0 231 174 007 /022 905 205 O 0 237 022 025 / 025 905 205 D And this one, which I think is from a 1975 1.8 and appears to be in the best shape: 0 231 176 048 / 021 905 205 A-B Also a few pics of the Dellortos. Attached thumbnail(s) |
andrewvolsen Distributor Recommendation for 2056 w/ Carbs Nov 9 2026, 01:06 PM
Superhawk996 You have a number of hurdles in your way.
The We... Nov 9 2026, 01:22 PM
andrewvolsen Thanks for the distributor advance chart, that... Nov 9 2026, 01:55 PM
Superhawk996
I have a set of Dellorto 40 DRLAs - would they b... Nov 9 2026, 02:00 PM
emerygt350 Wasn't there two 009s? The Volkswagen one was... Nov 9 2026, 03:09 PM
Superhawk996
Wasn't there two 009s? The Volkswagen one wa... Nov 9 2026, 03:21 PM
Jack Standz
I am working on rebuilding the carbs and tuning t... Nov 9 2026, 04:13 PM
Jack Standz What are the part numbers on the distributors you... Nov 9 2026, 04:19 PM
andrewvolsen I'll inventory the distributors I have this ev... Nov 9 2026, 06:17 PM
930cabman I like the 009 on my 2056 with twin Weber 40IDF... Nov 10 2026, 05:58 AM
andrewvolsen
I like the 009 on my 2056 with twin Weber 40IDF... Nov 10 2026, 11:22 AM
930cabman
I like the 009 on my 2056 with twin Weber 40IDF... Nov 10 2026, 01:17 PM
Jack Standz Those DRLA40s are good carbs, we have run a pair o... Nov 10 2026, 01:55 PM
andrewvolsen
Your "best" one looks to be from a bus/... Nov 10 2026, 06:27 PM
North Coast Jim
I am working on rebuilding the carbs and tuning t... Nov 10 2026, 02:27 PM
andrewvolsen
With the advance curve we use it has no flats spo... Nov 10 2026, 05:42 PM
North Coast Jim
With the advance curve we use it has no flats sp... Nov 12 2026, 10:08 AM
rfinegan I had great success with a Malory Unilite and MSD... Nov 10 2026, 04:29 PM
porschetub Think the 1.8 dizzy you have will work as a good ... Nov 10 2026, 10:47 PM
andrewvolsen While working on the throttle linkage last night (... Nov 11 2026, 10:54 AM
emerygt350 Yep. Nov 11 2026, 12:04 PM
Jack Standz
While working on the throttle linkage last night ... Nov 12 2026, 12:02 AM
VaccaRabite 1) You 100% need the cooling flaps installed. The... Nov 12 2026, 07:28 PM
andrewvolsen
1) You 100% need the cooling flaps installed. Th... Nov 13 2026, 10:50 AM
VaccaRabite
1) You 100% need the cooling flaps installed. T... Nov 16 2026, 10:41 AM
Jack Standz Here's some more distributor curve graphs for ... Nov 12 2026, 08:38 PM
andrewvolsen I looked through a few more boxes of parts and fou... Nov 13 2026, 11:10 AM
emerygt350 sell them and use the proceeds for a 123...
Keep ... Nov 13 2026, 01:38 PM
andrewvolsen Pulled the motor out this morning. Will install th... Nov 13 2026, 03:32 PM
andrewvolsen Oil leaks - one spot smelled like gear oil, the ot... Nov 13 2026, 03:51 PM
Jack Standz If you aren't planning on running fuel injecti... Nov 13 2026, 05:07 PM
brant Allegedly
One of the two 1.8 distributors has th... Nov 13 2026, 09:48 PM
andrewvolsen Does anybody sell a grommet kit containing all of ... Nov 14 2026, 10:08 AM
emerygt350
Does anybody sell a grommet kit containing all of... Nov 14 2026, 03:19 PM
andrewvolsen Do I need to swap this fan housing for one with a ... Nov 15 2026, 10:23 AM
andrewvolsen I removed the transaxle, exhaust, intake parts, an... Nov 15 2026, 05:06 PM
emerygt350 None of this looks bad. I would start a new threa... Nov 15 2026, 06:05 PM
andrewvolsen
None of this looks bad. I would start a new thre... Nov 15 2026, 07:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 07:14 AM |
