| andrewvolsen |
Nov 9 2026, 01:06 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
I am working on rebuilding the carbs and tuning the engine in my '74. What I know (or was told) about it:
From what I've gathered reading other carb and ignition tuning threads on this forum, the 009 is not considered a good distributor for this engine. I have a big box of stock 914 distributors to choose from - which one would be a good choice? |
| North Coast Jim |
Nov 10 2026, 02:27 PM
Member ![]() ![]() Group: Members Posts: 351 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
I run a 2056cc weber carb engine, using 40IDFs with 28mm chokes. It has a Web cam for carbs. Struggled with an 009 disti and exchanged it for a 123 disti. With the advance curve we use it has no flats spots and pulls all the way to redline. Starts better too. Quite happy with the set up. The 123 is a plug and play swap. Make the purchase when they go on sale. |
andrewvolsen Distributor Recommendation for 2056 w/ Carbs Nov 9 2026, 01:06 PM
Superhawk996 You have a number of hurdles in your way.
The We... Nov 9 2026, 01:22 PM
andrewvolsen Thanks for the distributor advance chart, that... Nov 9 2026, 01:55 PM
Superhawk996
I have a set of Dellorto 40 DRLAs - would they b... Nov 9 2026, 02:00 PM
emerygt350 Wasn't there two 009s? The Volkswagen one was... Nov 9 2026, 03:09 PM
Superhawk996
Wasn't there two 009s? The Volkswagen one wa... Nov 9 2026, 03:21 PM
Jack Standz
I am working on rebuilding the carbs and tuning t... Nov 9 2026, 04:13 PM
Jack Standz What are the part numbers on the distributors you... Nov 9 2026, 04:19 PM
andrewvolsen I'll inventory the distributors I have this ev... Nov 9 2026, 06:17 PM
andrewvolsen I have these distributors in a box, in varying con... Nov 9 2026, 09:28 PM
930cabman I like the 009 on my 2056 with twin Weber 40IDF... Nov 10 2026, 05:58 AM
andrewvolsen
I like the 009 on my 2056 with twin Weber 40IDF... Nov 10 2026, 11:22 AM
930cabman
I like the 009 on my 2056 with twin Weber 40IDF... Nov 10 2026, 01:17 PM
Jack Standz Those DRLA40s are good carbs, we have run a pair o... Nov 10 2026, 01:55 PM
andrewvolsen
Your "best" one looks to be from a bus/... Nov 10 2026, 06:27 PM
andrewvolsen
With the advance curve we use it has no flats spo... Nov 10 2026, 05:42 PM
North Coast Jim
With the advance curve we use it has no flats sp... Nov 12 2026, 10:08 AM
rfinegan I had great success with a Malory Unilite and MSD... Nov 10 2026, 04:29 PM
porschetub Think the 1.8 dizzy you have will work as a good ... Nov 10 2026, 10:47 PM
andrewvolsen While working on the throttle linkage last night (... Nov 11 2026, 10:54 AM
emerygt350 Yep. Nov 11 2026, 12:04 PM
Jack Standz
While working on the throttle linkage last night ... Nov 12 2026, 12:02 AM
VaccaRabite 1) You 100% need the cooling flaps installed. The... Nov 12 2026, 07:28 PM
andrewvolsen
1) You 100% need the cooling flaps installed. Th... Nov 13 2026, 10:50 AM
VaccaRabite
1) You 100% need the cooling flaps installed. T... Nov 16 2026, 10:41 AM
Jack Standz Here's some more distributor curve graphs for ... Nov 12 2026, 08:38 PM
andrewvolsen I looked through a few more boxes of parts and fou... Nov 13 2026, 11:10 AM
emerygt350 sell them and use the proceeds for a 123...
Keep ... Nov 13 2026, 01:38 PM
andrewvolsen Pulled the motor out this morning. Will install th... Nov 13 2026, 03:32 PM
andrewvolsen Oil leaks - one spot smelled like gear oil, the ot... Nov 13 2026, 03:51 PM
Jack Standz If you aren't planning on running fuel injecti... Nov 13 2026, 05:07 PM
brant Allegedly
One of the two 1.8 distributors has th... Nov 13 2026, 09:48 PM
andrewvolsen Does anybody sell a grommet kit containing all of ... Nov 14 2026, 10:08 AM
emerygt350
Does anybody sell a grommet kit containing all of... Nov 14 2026, 03:19 PM
andrewvolsen Do I need to swap this fan housing for one with a ... Nov 15 2026, 10:23 AM
andrewvolsen I removed the transaxle, exhaust, intake parts, an... Nov 15 2026, 05:06 PM
emerygt350 None of this looks bad. I would start a new threa... Nov 15 2026, 06:05 PM
andrewvolsen
None of this looks bad. I would start a new thre... Nov 15 2026, 07:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 07:14 AM |
