> Distributor Recommendation for 2056 w/ Carbs
andrewvolsen
post Nov 9 2026, 01:06 PM
I am working on rebuilding the carbs and tuning the engine in my '74. What I know (or was told) about it:
  • 2056 built on 1.8 EC case and heads
  • aftermarket cam (unknown which)
  • weber 44 idf carbs with 32mm venturis
  • new aftermarket 009 distributor
  • SSI 1.7/1.8 heat exchangers with bursch type muffler
From what I've gathered reading other carb and ignition tuning threads on this forum, the 009 is not considered a good distributor for this engine. I have a big box of stock 914 distributors to choose from - which one would be a good choice?
Jack Standz
post Nov 10 2026, 01:55 PM
Those DRLA40s are good carbs, we have run a pair on a 914, slightly different than a Weber IDF40, but work at least as well. Nicely suited for your 2056 if the venturis aren't too large, the shafts don't leak too much, and they are within specifications after being rebuilt.
Distributors:
That's quite a collection across the VW world of motors.
Your "best" one looks to be from a bus/pickup and has a vacuum canister:
Advance/Retard Range
Vacuum: 8-11deg Adv @ 7.9 In. Hg, 11-13deg Ret @7.9 In. Hg; Centrifigual: 11-17deg @ 2000 rpm, 21-25deg @ 3600 rpm
Suggest these considerations for your choice of distributor:
Centrifugal advance only version (vacuum may work if you put a t in the vacuum line and run an anti pulse valve, if the vacuum signal is sufficient and your vacuum canister isn't too small because those require more vacuum)
Has a curve you like for your 2056
Use a good ignition coil
Use that compufire unit if it works
Check that bushings not too worn
The 009 may be the best suited to your application that you have, not sure. Check out this link and other sources and compare it to your constraints for a distributor:
https://aircooledoutfitters.com/distributors-by-bosch-number
We ran an 009 for over 10 years on a 914 even though there were better available options.
Best wishes for getting her sorted out!
andrewvolsen
post Nov 10 2026, 06:27 PM
QUOTE(Jack Standz @ Nov 10 2026, 11:55 AM) *
The 0 231 176 048 / 021 905 205 AB distributor seems to be listed as both 75-76 bus and 914 1.8 applications, depending on data source. They may be confusing the 021 905 205 AB (75-76 bus) that I have with 022 905 205 AB (914 1.8)?
Matching the distributor numbers I recorded with applications, I came up with these as originating in 914s. I will take another look at them to pick out those in the best condition. I also have distributors in three GA core engines that I forgot to inspect last night.
0 231 174 009 / 039 905 205 ; 914 2.0
0 231 172 019 / 022 905 205 P ; 914 1.7
0 231 181 009 / 022 905 205 AA ; 914 1.8
0 231 174 005 / 113 (022?) 905 205 F (3X) ; 914 1.7
0 231 124 021 / 039 905 205 B ; 914 2.0 Cal 75-76
0 231 174 007 / 022 905 205 O (Q?) ; 914 1.7 late
0 231 176 048 / 021 905 205 AB ; Bus and Pickup 75-76, 914 1.8?
And these that are not 914 applications.
REPRO 009s ; Industrial
0 231 178 009 (2X) ; Industrial
0 231 167 070 / 113 905 205 AH ; Beetle 72-73
0 237 022 025 / 025 905 205 D ; Vanagon 83-84
Distributor application sources:
https://members.rennlist.com/pbanders/DJetParts.htm
https://www.restoration-design.com/pdf/PET%...201970-1976.pdf
https://www.thesamba.com/vw/archives/manual...ne_Up_Parts.pdf
andrewvolsen   Distributor Recommendation for 2056 w/ Carbs   Nov 9 2026, 01:06 PM
Superhawk996   You have a number of hurdles in your way. The We...   Nov 9 2026, 01:22 PM
andrewvolsen   Thanks for the distributor advance chart, that...   Nov 9 2026, 01:55 PM
Superhawk996   I have a set of Dellorto 40 DRLAs - would they b...   Nov 9 2026, 02:00 PM
emerygt350   Wasn't there two 009s? The Volkswagen one was...   Nov 9 2026, 03:09 PM
Superhawk996   Wasn't there two 009s? The Volkswagen one wa...   Nov 9 2026, 03:21 PM
Jack Standz   I am working on rebuilding the carbs and tuning t...   Nov 9 2026, 04:13 PM
Jack Standz   What are the part numbers on the distributors you...   Nov 9 2026, 04:19 PM
andrewvolsen   I'll inventory the distributors I have this ev...   Nov 9 2026, 06:17 PM
andrewvolsen   I have these distributors in a box, in varying con...   Nov 9 2026, 09:28 PM
930cabman   I like the 009 on my 2056 with twin Weber 40IDF...   Nov 10 2026, 05:58 AM
andrewvolsen   I like the 009 on my 2056 with twin Weber 40IDF...   Nov 10 2026, 11:22 AM
930cabman   I like the 009 on my 2056 with twin Weber 40IDF...   Nov 10 2026, 01:17 PM
Jack Standz   Those DRLA40s are good carbs, we have run a pair o...   Nov 10 2026, 01:55 PM
andrewvolsen   Your "best" one looks to be from a bus/...   Nov 10 2026, 06:27 PM
North Coast Jim   I am working on rebuilding the carbs and tuning t...   Nov 10 2026, 02:27 PM
andrewvolsen   With the advance curve we use it has no flats spo...   Nov 10 2026, 05:42 PM
North Coast Jim   With the advance curve we use it has no flats sp...   Nov 12 2026, 10:08 AM
rfinegan   I had great success with a Malory Unilite and MSD...   Nov 10 2026, 04:29 PM
porschetub   Think the 1.8 dizzy you have will work as a good ...   Nov 10 2026, 10:47 PM
andrewvolsen   While working on the throttle linkage last night (...   Nov 11 2026, 10:54 AM
emerygt350   Yep.   Nov 11 2026, 12:04 PM
Jack Standz   While working on the throttle linkage last night ...   Nov 12 2026, 12:02 AM
VaccaRabite   1) You 100% need the cooling flaps installed. The...   Nov 12 2026, 07:28 PM
andrewvolsen   1) You 100% need the cooling flaps installed. Th...   Nov 13 2026, 10:50 AM
VaccaRabite   1) You 100% need the cooling flaps installed. T...   Nov 16 2026, 10:41 AM
Jack Standz   Here's some more distributor curve graphs for ...   Nov 12 2026, 08:38 PM
andrewvolsen   I looked through a few more boxes of parts and fou...   Nov 13 2026, 11:10 AM
emerygt350   sell them and use the proceeds for a 123... Keep ...   Nov 13 2026, 01:38 PM
andrewvolsen   Pulled the motor out this morning. Will install th...   Nov 13 2026, 03:32 PM
andrewvolsen   Oil leaks - one spot smelled like gear oil, the ot...   Nov 13 2026, 03:51 PM
Jack Standz   If you aren't planning on running fuel injecti...   Nov 13 2026, 05:07 PM
brant   Allegedly One of the two 1.8 distributors has th...   Nov 13 2026, 09:48 PM
andrewvolsen   Does anybody sell a grommet kit containing all of ...   Nov 14 2026, 10:08 AM
emerygt350   Does anybody sell a grommet kit containing all of...   Nov 14 2026, 03:19 PM
andrewvolsen   Do I need to swap this fan housing for one with a ...   Nov 15 2026, 10:23 AM
andrewvolsen   I removed the transaxle, exhaust, intake parts, an...   Nov 15 2026, 05:06 PM
emerygt350   None of this looks bad. I would start a new threa...   Nov 15 2026, 06:05 PM
andrewvolsen   None of this looks bad. I would start a new thre...   Nov 15 2026, 07:03 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 07:14 AM
