> Distributor Recommendation for 2056 w/ Carbs
andrewvolsen
post Nov 9 2026, 01:06 PM
I am working on rebuilding the carbs and tuning the engine in my '74. What I know (or was told) about it:
  • 2056 built on 1.8 EC case and heads
  • aftermarket cam (unknown which)
  • weber 44 idf carbs with 32mm venturis
  • new aftermarket 009 distributor
  • SSI 1.7/1.8 heat exchangers with bursch type muffler
From what I've gathered reading other carb and ignition tuning threads on this forum, the 009 is not considered a good distributor for this engine. I have a big box of stock 914 distributors to choose from - which one would be a good choice?
andrewvolsen
post Nov 14 2026, 10:08 AM
Does anybody sell a grommet kit containing all of the grommets for the engine tin and any others in the engine bay?
emerygt350
post Nov 14 2026, 03:19 PM
QUOTE(andrewvolsen @ Nov 14 2026, 11:08 AM) *
I would start at 914rubber
andrewvolsen   Distributor Recommendation for 2056 w/ Carbs   Nov 9 2026, 01:06 PM
Superhawk996   You have a number of hurdles in your way. The We...   Nov 9 2026, 01:22 PM
andrewvolsen   Thanks for the distributor advance chart, that...   Nov 9 2026, 01:55 PM
Superhawk996   I have a set of Dellorto 40 DRLAs - would they b...   Nov 9 2026, 02:00 PM
emerygt350   Wasn't there two 009s? The Volkswagen one was...   Nov 9 2026, 03:09 PM
Superhawk996   Wasn't there two 009s? The Volkswagen one wa...   Nov 9 2026, 03:21 PM
Jack Standz   I am working on rebuilding the carbs and tuning t...   Nov 9 2026, 04:13 PM
Jack Standz   What are the part numbers on the distributors you...   Nov 9 2026, 04:19 PM
andrewvolsen   I'll inventory the distributors I have this ev...   Nov 9 2026, 06:17 PM
andrewvolsen   I have these distributors in a box, in varying con...   Nov 9 2026, 09:28 PM
930cabman   I like the 009 on my 2056 with twin Weber 40IDF...   Nov 10 2026, 05:58 AM
andrewvolsen   I like the 009 on my 2056 with twin Weber 40IDF...   Nov 10 2026, 11:22 AM
930cabman   I like the 009 on my 2056 with twin Weber 40IDF...   Nov 10 2026, 01:17 PM
Jack Standz   Those DRLA40s are good carbs, we have run a pair o...   Nov 10 2026, 01:55 PM
andrewvolsen   Your "best" one looks to be from a bus/...   Nov 10 2026, 06:27 PM
North Coast Jim   I am working on rebuilding the carbs and tuning t...   Nov 10 2026, 02:27 PM
andrewvolsen   With the advance curve we use it has no flats spo...   Nov 10 2026, 05:42 PM
North Coast Jim   With the advance curve we use it has no flats sp...   Nov 12 2026, 10:08 AM
rfinegan   I had great success with a Malory Unilite and MSD...   Nov 10 2026, 04:29 PM
porschetub   Think the 1.8 dizzy you have will work as a good ...   Nov 10 2026, 10:47 PM
andrewvolsen   While working on the throttle linkage last night (...   Nov 11 2026, 10:54 AM
emerygt350   Yep.   Nov 11 2026, 12:04 PM
Jack Standz   While working on the throttle linkage last night ...   Nov 12 2026, 12:02 AM
VaccaRabite   1) You 100% need the cooling flaps installed. The...   Nov 12 2026, 07:28 PM
andrewvolsen   1) You 100% need the cooling flaps installed. Th...   Nov 13 2026, 10:50 AM
VaccaRabite   1) You 100% need the cooling flaps installed. T...   Nov 16 2026, 10:41 AM
Jack Standz   Here's some more distributor curve graphs for ...   Nov 12 2026, 08:38 PM
andrewvolsen   I looked through a few more boxes of parts and fou...   Nov 13 2026, 11:10 AM
emerygt350   sell them and use the proceeds for a 123... Keep ...   Nov 13 2026, 01:38 PM
andrewvolsen   Pulled the motor out this morning. Will install th...   Nov 13 2026, 03:32 PM
andrewvolsen   Oil leaks - one spot smelled like gear oil, the ot...   Nov 13 2026, 03:51 PM
Jack Standz   If you aren't planning on running fuel injecti...   Nov 13 2026, 05:07 PM
brant   Allegedly One of the two 1.8 distributors has th...   Nov 13 2026, 09:48 PM
andrewvolsen   Does anybody sell a grommet kit containing all of ...   Nov 14 2026, 10:08 AM
emerygt350   Does anybody sell a grommet kit containing all of...   Nov 14 2026, 03:19 PM
andrewvolsen   Do I need to swap this fan housing for one with a ...   Nov 15 2026, 10:23 AM
andrewvolsen   I removed the transaxle, exhaust, intake parts, an...   Nov 15 2026, 05:06 PM
emerygt350   None of this looks bad. I would start a new threa...   Nov 15 2026, 06:05 PM
andrewvolsen   None of this looks bad. I would start a new thre...   Nov 15 2026, 07:03 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 07:14 AM
