> Electric A/C anyone?, Comments, dialog, experience?
slowrodent
post May 20 2025, 11:37 AM
OK..I've read a bunch of semi-recent articles online regarding electric air conditioning kits in cars. One was a 911 that is employing a rather pricey euro-kit and the owner seemed pleased... Most articles focus on the large current draw and the overall (in)efficiency of the kits on the whole. Yet, I can't help but feel that the 914 (tiny car) is a perfect application for such a kit - particularly if your engine can push a larger alternator. (Mine is a v6 and would have no problem doing so).. Allows you to frunk-mount the compressor and simplify the overall install (yes, big gauge wires are required, but in my case at least.. no interior exists so no worries)
Plus relatively cheap kits are waaay-abundant.
So thoughts, insights, experience? (IMG:style_emoticons/default/idea.gif)
post Nov 22 2026, 01:57 PM
914-6 GT in waiting
Yea, the pms install looks clean but I was always told no horizontal condensers. I don’t know if that’s true or not since the Carrera’s front condenser is horizontal. I’m less concerned about oil temp than a/c condenser efficiency. I figure direct air on the ac condenser at speed is probably optimal. Big auxiliary fan when slow or stopped. But maybe there is something better.
I’m not really satisfied with mine since it will take a bunch of custom brackets and such to make it work but who knows what’s best.
According to AI.
can an automotive a/c condenser be mounted horizontal
No, a standard automotive A/C condenser generally should not be mounted flat or horizontally—it must be mounted vertically so gas enters at the top and liquid exits at the bottom.
Why Vertical Mounting Matters
• Proper refrigerant flow: Hot vapor enters the top inlet and condenses into liquid as it moves down toward the bottom outlet.
• Compressor oil return: Laying a parallel-flow condenser flat can trap lubricating oil inside the core, starving the A/C compressor and risking failure.
• Condensing efficiency: Liquid needs to drain cleanly rather than pool or be pushed uphill against incoming vapor.
slowrodent   Electric A/C anyone?   May 20 2025, 11:37 AM
76-914   Keith @914Toy did it and loved it before he sold...   May 20 2025, 11:44 AM
VaccaRabite   As long as your alternator can push the power, its...   May 20 2025, 02:42 PM
mepstein   As long as your alternator can push the power, it...   May 20 2025, 05:26 PM
Spoke   I'm not up enough on /6 stuff to know about t...   May 21 2025, 08:47 AM
VaccaRabite   I'm not up enough on /6 stuff to know about ...   May 22 2025, 06:25 AM
ClayPerrine   Mine is in process. I have the compressor kit, and...   May 20 2025, 03:07 PM
Chris914n6   On a car the size of a 914 the compressor won...   May 20 2025, 04:23 PM
mepstein   On a car the size of a 914 the compressor won...   May 20 2025, 05:30 PM
Montreal914   Regardless of cabin size, using a stock 3.2 altern...   May 21 2025, 07:50 AM
ClayPerrine   [quote name='mepstein' post='3206454' date='May 2...   May 21 2025, 08:06 AM
Chris914n6   [quote name='mepstein' post='3206454' date='May ...   May 22 2025, 12:14 PM
mepstein   [quote name='mepstein' post='3206454' date='May ...   May 22 2025, 01:03 PM
Steve   [quote name='mepstein' post='3206454' date='May ...   Aug 29 2025, 04:10 PM
Shivers   Has anyone here had success swapping to a GM or ot...   May 20 2025, 06:51 PM
ClayPerrine   On Elwood (the original six) I have considered upg...   May 20 2025, 08:40 PM
Shivers   On Elwood (the original six) I have considered up...   May 20 2025, 09:48 PM
burton73   On Elwood (the original six) I have considered up...   May 21 2025, 12:16 PM
Superhawk996   Problem solved   May 20 2025, 10:04 PM
mate914   Problem solved That's pet mode. I like it. ...   May 21 2025, 06:02 AM
Montreal914   @Steve :popcorn:   May 20 2025, 11:11 PM
Shivers   @Superhawk996 That’s funny Phil :D 12V 4400...   May 21 2025, 08:12 AM
Jack Standz   Has anyone here had success swapping to a GM or o...   May 21 2025, 08:44 AM
Shivers   Has anyone here had success swapping to a GM or ...   May 21 2025, 08:53 AM
Steve   I would use a standard modern compressor on a wate...   May 21 2025, 10:44 AM
mepstein   Paint it black and it will look like a small cargo...   May 21 2025, 01:51 PM
Shivers   It’s a Gurney Bubble to fit my fat head. That’...   May 21 2025, 02:05 PM
Highland   Could one use a battery to power the compressor an...   May 21 2025, 06:12 PM
mepstein   Could one use a battery to power the compressor a...   May 21 2025, 06:47 PM
Root_Werks   Could one use a battery to power the compressor ...   May 22 2025, 10:27 AM
Highland   [quote name='mepstein' post='3206620' date='May 2...   May 22 2025, 12:35 PM
Root_Werks   [quote name='mepstein' post='3206620' date='May ...   May 22 2025, 01:05 PM
Superhawk996   So maybe I'm showing my ignorance, but a 60...   May 30 2025, 07:19 AM
Chris914n6   It's a typical hybrid. So there is the tractio...   May 22 2025, 05:45 PM
Superhawk996   It's a typical hybrid. So there is the tracti...   May 30 2025, 07:21 AM
Steve   I did some more testing at 70 degrees in the garag...   May 29 2025, 09:52 PM
mate914   Hi Can I see a pic of the under dash evaporator in...   May 30 2025, 05:38 AM
JmuRiz   Hi Can I see a pic of the under dash evaporator i...   May 30 2025, 10:13 AM
Steve   Hi Can I see a pic of the under dash evaporator i...   May 30 2025, 10:33 AM
Steve   This looks like my compressor on Amazon. https://...   May 29 2025, 10:26 PM
nditiz1   Adding some facts into this thread. The CR AC wil...   May 30 2025, 05:38 AM
Steve   Adding some facts into this thread. The CR AC wi...   May 30 2025, 11:03 AM
nditiz1   Steve, I didn't know you built a setup. That ...   May 30 2025, 03:17 PM
mepstein   Steve, I didn't know you built a setup. That...   May 30 2025, 05:00 PM
mepstein   @Steve Steve - Where are you mounting the condens...   Aug 28 2025, 08:07 PM
Steve   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 28 2025, 11:05 PM
Steve   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 29 2025, 09:56 AM
mepstein   [b]@[url=http://www.914world.com/bbs2/index.php?...   Aug 29 2025, 10:04 AM
Steve   [quote name='Steve' post='3221744' date='Aug 29 2...   Aug 29 2025, 11:11 AM
Steve   [quote name='Steve' post='3221744' date='Aug 29 2...   Sep 3 2025, 04:15 PM
mepstein   [quote name='Steve' post='3221744' date='Aug 29 ...   Sep 3 2025, 04:31 PM
Steve   The only issue I am dealing with now is I used a 4...   Aug 29 2025, 09:44 AM
Dave_Darling   ... I used a 4 gauge crappy non copper Amazon Chi...   Aug 31 2025, 11:50 PM
Steve   ... I used a 4 gauge crappy non copper Amazon Ch...   Sep 1 2025, 09:52 AM
mepstein   I bought a CR unit to put in my 914-6. The evapora...   Aug 29 2025, 11:21 AM
mepstein   When the units first came out ten years ago, I wor...   Aug 29 2025, 05:24 PM
Steve   When the units first came out ten years ago, I wo...   Aug 29 2025, 08:05 PM
914sgofast2   Why not just add a deep cycle battery in the rear ...   Aug 30 2025, 12:08 AM
Steve   Why not just add a deep cycle battery in the rear...   Aug 30 2025, 07:10 AM
Steve   Nice to know a USA electric compressor is now avai...   Aug 31 2025, 07:37 PM
Steve   I was recently looking at the Southern Rods web si...   Nov 22 2026, 11:53 AM
mepstein   Steve - I thought you had the Griffiths condenser ...   Nov 22 2026, 12:07 PM
Steve   Steve - I thought you had the Griffiths condenser...   Nov 22 2026, 12:24 PM
mepstein   I’m still mocking up ideas. Here’s the latest ...   Nov 22 2026, 12:38 PM
Steve   I’m still mocking up ideas. Here’s the latest...   Nov 22 2026, 01:25 PM
mepstein   Yea, the pms install looks clean but I was always ...   Nov 22 2026, 01:57 PM
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: bob164
- Lo-Fi Version Time is now: 23rd November 2026 - 01:39 AM
