| peteinjp |
Nov 3 2026, 05:13 AM
Member ![]() ![]() Group: Members Posts: 227 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None
I have the rear trailing arm off for replacement and looking at the oil tank.... the paint job was obviously not up for the task. The car only has a 4000 miles since this was installed new. Everything on this car (snoopy) was done with new and or original style parts so from a visual perspective it all looks original. But I just can't see how the steel tank wouldn't be better if it was aluminum. The filler neck is also a reproduction part and has tons of rust from condensation- surprising considering how much this stuff costs!
So- I'm on the fence- pull what I have and send it out for some type of 2 part epoxy treatment and get the filler neck cad plated, do my best with a wire brush and use some quality rubberized spray (not great for heat transfer- if that matters) or sell it and go all aluminum. Also seems like a good idea to get the chrome trim back on with the tank out.... Pete |
| peteinjp |
Nov 23 2026, 01:34 AM
Got the tank out a while back- no issues. Finally bought a good oil drain tank/pan with a huge bowl to use under the lift- literally didn't spill a drop. Beginners luck I suppose.Next time I'll probably be getting out the kitty litter....
Anyway- tank is copper coated and in functionally excellent shape. So if it's true that the repro tanks do not have the copper then I guess this is very nicely preserved original- maybe even it was N.O.S...? Evidence of copper coating ![]() There was nothing between this nut and the body on either the tank side or the engine side- seems something should be in there- any thoughts? ![]() Here you can see where the copper coating has already been worn though and start gin to rust. ![]() Unfortunately there is a huge dent but- well I'll forget all about that as soon as the cars on the road again. ![]() Sending it out for a solid 2 part treatment and some stone guard spray in selected areas. This is despite the car having aftermarket inner fender covers BTW. Pete |
peteinjp Oil tank removal- stay stock or go aluminum? Nov 3 2026, 05:13 AM
mepstein The steel reproduction tanks don't have the co... Nov 3 2026, 06:44 AM
bdstone914 If you go with one of Bens aluminum tanks get one... Nov 3 2026, 08:01 AM
930cabman Depends on how married you are to originality, any... Nov 3 2026, 08:53 AM
Cairo94507 An original tank has a lot of appeal; pull it and ... Nov 3 2026, 09:30 AM
Root_Werks
An original tank has a lot of appeal; pull it and... Nov 3 2026, 09:53 AM
Shivers Hi Pete. :wavebye: I know you've had this ca... Nov 3 2026, 09:48 AM
rgalla9146 Rust on the filler neck and the cap is very common... Nov 3 2026, 10:36 AM
peteinjp Lots of great feedback. I'm not really into ad... Nov 3 2026, 06:07 PM
Shivers
Lots of great feedback. I'm not really into a... Nov 3 2026, 07:13 PM
mb911
Lots of great feedback. I'm not really into a... Nov 3 2026, 08:32 PM
peteinjp Not a real 6... but looks the part in most ways. J... Nov 4 2026, 01:37 AM
morehills I would never blast and powder coat one of these t... Nov 23 2026, 05:24 AM
peteinjp
I would never blast and powder coat one of these ... Nov 23 2026, 06:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 01:16 PM |
