| timofly |
Nov 24 2026, 11:28 AM
Member ![]() ![]() Group: Members Posts: 180 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
In ambient temperatures below 80F, alternator light and in-console voltmeter show discharge after startup. That continues for varying amounts of time, from 2-3 minutes in warrmer temps, longer when it's colder. Applying lots of throttle can sometimes extinguish light and voltmeter shows a charge. The engine idles normally until the alternator appears to wake up (light goes out, VM shows a charge) when it drops 200 rpm or more, so it apparently is loading. Once the light and VM indicate a charge, it's good to go for as long as I drive it, even with a few stops during the drive.
In sum, the alternator seems to be temperature and RPM sensitive. Belt is tight, connections have been checked for normal resistance, and the condition goes away once the car is well warmed up. Recent driving shows a worsening of the problem, so I need to see what the Brain Trust here thinks. |
worn
In ambient temperatures below 80F, alternator lig... Nov 24 2026, 06:51 PM
emerygt350 Are you still using an old school voltage regulato... Nov 24 2026, 07:26 PM
Superhawk996 Brushes likely getting worn near wear limit with l... Nov 24 2026, 07:51 PM
anderssj
Brushes likely getting worn near wear limit with ... Nov 24 2026, 09:39 PM
porschetub
In ambient temperatures below 80F, alternator lig... Nov 24 2026, 10:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 10:51 PM |
