| timofly |
Nov 24 2026, 11:28 AM
Member ![]() ![]() Group: Members Posts: 180 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
In ambient temperatures below 80F, alternator light and in-console voltmeter show discharge after startup. That continues for varying amounts of time, from 2-3 minutes in warrmer temps, longer when it's colder. Applying lots of throttle can sometimes extinguish light and voltmeter shows a charge. The engine idles normally until the alternator appears to wake up (light goes out, VM shows a charge) when it drops 200 rpm or more, so it apparently is loading. Once the light and VM indicate a charge, it's good to go for as long as I drive it, even with a few stops during the drive.
In sum, the alternator seems to be temperature and RPM sensitive. Belt is tight, connections have been checked for normal resistance, and the condition goes away once the car is well warmed up. Recent driving shows a worsening of the problem, so I need to see what the Brain Trust here thinks. |
| Superhawk996 |
Nov 24 2026, 07:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,191 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Brushes likely getting worn near wear limit with less spring pressure to keep them in contact with the armature or getting sticky in their brush holders inside the alternator.
Emery’s question above is valid too if using the points based mechanical voltage regulator - could be sticking there too. |
| anderssj |
Nov 24 2026, 09:39 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,810 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
Brushes likely getting worn near wear limit with less spring pressure to keep them in contact with the armature or getting sticky in their brush holders inside the alternator. (IMG:style_emoticons/default/agree.gif) I had the same problem a year ago. I had the alternator rebuilt locally; both brushes were worn, one was well below wear limit... |
timofly Weird alternator fault Nov 24 2026, 11:28 AM
worn
In ambient temperatures below 80F, alternator lig... Nov 24 2026, 06:51 PM
emerygt350 Are you still using an old school voltage regulato... Nov 24 2026, 07:26 PM
porschetub
In ambient temperatures below 80F, alternator lig... Nov 24 2026, 10:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 10:51 PM |
