> They towed my baby home., starter, carbs, hydrolock?
Lawrence
post Jun 5 2003, 03:18 PM
Car had been acting wierd since the last fillup, especially when starting from a dead stop. Unfortunately, I put 89 grade ethanol in it, without reading the pump. (Best grade they had.) I figured that the problem might be minor vaporlock or just poor performance from the crap gas.
Well, on the way to work, the car was acting worse. Several times the car just stalled at an intersection, and I'd have to give it lots of gas to start. Starting was very hard.
At lunch, the car wouldn't start. I noticed the outside of the right carb was dripping. Checked hoses, and tried to start again. Engine started to turn - then stopped abruptly. Let it set, and it finally started.
I went to get gas and stop by BK for lunch. I filled it up to dilute the ethanol, which I still believed was most of the problem. In the drivethru, it stalled twice. I couldn't get it to start the second time, so I pushed my 914 through the BK drivethrough. How embarrassing.
Well, I get it out of the way, and try to start it again. Same "locked" problem. Give it a few minutes, and the starter clicks once. Hmmm. Battery dead? Try to start one more time, and now the starter whirrs freely, like the gear was broken off the end.
Here's my hypothesis/diagnosis:
Right side carb has a needle valve stuck open. Would cause poor running problems at low RPMs. When the key is set in the run position, it starts to fill 1 or more cylinders with fuel. Starting the car, I had a partial hydrolock. I didn't ever try to push-start the car down a hill or anything. The resistance from the engine damaged the starter.
Thoughts? Comments? Bets?
-Rusty
Lawrence
post Jun 5 2003, 07:30 PM
It's raining like cats and dogs in Kansas. I'm almost dry.
It only took 30 minutes to pull the starter. Thank God that I had the factory manuals. I'd have been really pissed to struggle for HOURS to find out that the upper bolt requires an 8mm allen head socket.
I forgot to disconnect the battery. Can you sing along with me? "You light up my liiiiiiiife.... AHHHHHHH!"
Starter gear looks a bit worn, but not too bad. Flywheel is pretty chewed up, as far as I could feel in the hole. I've never had the starter or transmission off, so some of this is news to me. Looks like I'll probably need a replacement. I'll take the starter in for testing in the morning.
It's too wet to go out and take a picture, so I'll do that in the morning, too.
Still no answer on the REAL problem... too wet to pull the air cleaners.
-Rusty
Lawrence914-6   They towed my baby home.   Jun 5 2003, 03:18 PM
need4speed   clogged idle circuit? Don't know how to expla...   Jun 5 2003, 04:39 PM
Lawrence914-6   I thought about the battery.. but I have a Vortex ...   Jun 5 2003, 05:01 PM
Aaron Cox   ethanol? where'd ye buy that? what auto would ...   Jun 5 2003, 05:06 PM
Lawrence914-6   I pulled over for gas at a local station - most Mi...   Jun 5 2003, 05:16 PM
Mark Henry   <...   Jun 5 2003, 05:46 PM
Carl   Lawrence, I think you're stuck needle valve is...   Jun 5 2003, 05:55 PM
Lawrence914-6   It's raining like cats and dogs in Kansas. I...   Jun 5 2003, 07:30 PM
krk   Dude, I'm bummed to hear it. I'm with Car...   Jun 5 2003, 09:11 PM
Qarl   Bummer Lawrence. It's been raining for a whil...   Jun 5 2003, 09:38 PM
si2t3m   Hi Lawrence, I'd check the dizzy bolt first....   Jun 5 2003, 10:01 PM
Lawrence914-6   By the light of day... Flywheel is toast. Severa...   Jun 6 2003, 06:53 AM
MJHanna   Pull your spark plugs to make sure one cylinders i...   Jun 6 2003, 07:05 AM
krk   Broken teeth? Ouch!!! kim.   Jun 6 2003, 07:06 AM
Lawrence914-6
  Jun 6 2003, 07:11 AM
si2t3m   Sad new regarding the flywheel. :( This might be ...   Jun 6 2003, 08:17 AM
Lawrence914-6   New 914/6 flywheels are available, ~275.00 at Para...   Jun 6 2003, 09:54 AM
Lawrence914-6   Here are some pictures of the worn starter gear. ...   Jun 6 2003, 10:05 AM
Lawrence914-6   pic 2   Jun 6 2003, 10:05 AM
Lawrence914-6   pic 3   Jun 6 2003, 10:06 AM
Bleyseng   The starter looks fine but have it tested. Broken ...   Jun 6 2003, 10:22 AM
Carl   Lawrence, The gear on the starter looks OK. If th...   Jun 6 2003, 10:23 AM
Lawrence914-6   Hi Carl! Good to see you posting! :) I...   Jun 6 2003, 10:30 AM
Bleyseng   Wow the weather is a little different here, its in...   Jun 6 2003, 12:06 PM
Lawrence914-6   Must be nice... I don't remember sun till 10pm...   Jun 6 2003, 01:21 PM
Brian_Boss   I agree the starter pinion doesn't look too ba...   Jun 6 2003, 01:28 PM
Lawrence914-6   Well, there is good news. The starter checked out...   Jun 6 2003, 05:31 PM
ChrisReale   Rusty, you gonna turn Dirk Wright on us?   Jun 6 2003, 05:56 PM
Lawrence914-6   Turn? :lol2: While I'm replacing the flywhee...   Jun 6 2003, 05:59 PM
Gint   Uuuhhmmmmm.... Rusty, the entire suspension? I...   Jun 6 2003, 06:02 PM
Lawrence914-6   That was my plan... I'll have time to clean th...   Jun 6 2003, 06:07 PM
Gint   You going to blast them before you get here? THat...   Jun 6 2003, 06:10 PM
Lawrence914-6   I can. Or at least get a good start on them. If ...   Jun 6 2003, 06:11 PM
Gint   I dunno yet. My point was, blasting an entire fro...   Jun 6 2003, 06:17 PM
- Lo-Fi Version Time is now: 16th July 2025 - 04:02 PM
