Oil Leak, Is my mechanic right? |
dmilzoff |
Jun 6 2003, 05:12 PM
Member Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 |
I have a 914-6 with a 3.0. It has been used 1-200 miles per year for the past 4 years and has had moderate oil drips. I accepted the drips in my garage since I only used 1 quart of oil each year. I want to track the car now and I just had major work ($$$) done including changing oil from 50 weight to 10-30 Mobil 1. Now I have more leaks than ever - the car used 2 quarts of oil during 1 day of AutoX. I cannot see any oil leaking. My mechanic says it may be oil leaking past the valve guides into the combusiton chambers - meaning major overhaul and major cost.
Would returning to a higher weight oil (synthetic) help or is the overhaul necessary? Suggestions? Help!!!! |
ChrisReale |
Jun 6 2003, 06:08 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Synthetic oil doesnt start leaks, but it finds its way through the older seals. 2 quarts? Id say you have other issues.... (IMG:style_emoticons/default/sad.gif)
10w-30 is for Toyota's. If you are AXing, you might want to check out Mobil 1 15w-50. If you are using that much oil, it eithe ris leaking like mad, which you would probably see, because 2 quarts is a hell of a lot of oil to loose, or its going into the combustion chamber and burning up. Id take it to a Porsche mechanic, and have the proper tests done to determine if your heads need to be re worked |
Lo-Fi Version | Time is now: 10th June 2024 - 02:55 AM |
