Oil Temp Guage Troubleshooting |
Rand |
Feb 23 2005, 09:48 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
'75 with center console guages. Temp guage doesn't work. When ignition on, guage jumps off peg to bottom of temp scale on guage, but never moves from there. Guage has good ground and power. Temp sending unit? Is there a most problem-prone part of the oil temp guage system?
bd1308 |
Feb 23 2005, 09:55 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
i'm going to go with there is SOMETHING that the sending unit is grounding out too....becuase that position is where the needle goes when there is *nothing* hooked in....BTDT. if the engine is cold, it moves a little further out. Try and see if your connections are good--if you need help pm me....i've put mine in, and all of my wires werent good at all--i had to cut them and everything.
Lo-Fi Version | Time is now: 8th June 2024 - 01:17 PM |
