Oil Temp Guage Troubleshooting |
Rand |
Feb 23 2005, 09:48 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
'75 with center console guages. Temp guage doesn't work. When ignition on, guage jumps off peg to bottom of temp scale on guage, but never moves from there. Guage has good ground and power. Temp sending unit? Is there a most problem-prone part of the oil temp guage system?
Dave_Darling |
Feb 24 2005, 11:59 AM
I vote for broken or unplugged wire between the gauge and the sender. A grounded wire would send the gauge to max-hot position. (BTDT!)
It is possible for the sender to have failed with infinite (or near-infinite) resistance, but unlikely. Unplug the wire from the "G" terminal on the back of the gauge. What's the resistance from there to ground? If it's infinite, you have a broken connection somewhere between there and the sender. Check the engine bay, over on the right side, just below (sometimes just above) the sheet metal--near where the throttle cable comes through the engine shelf. Should be a single-wire box connector with a green/black (I think, maybe green/red?) wire going to it and going from it. --DD |
Lo-Fi Version | Time is now: 8th June 2024 - 08:07 AM |
