> REAR Control Arm - HELP !, Need Help
ajracer
post Feb 24 2005, 10:11 PM
Just thought someone might know the answer to my questions.
Problem is my Control arms appear to be really, really stiff in their
movement (after the struts were removed) With nothing restricting
their movement I found it very diffficult to move them up or down
to simulate the normal suspension travel !
The bushings appear to be just the factory "rubber' ones and nothing
seems to pivot very well. Is this normal ? Should I be concerned ?
Any comments are appreciated. Thanks
Allan
ArtechnikA
post Feb 25 2005, 01:00 PM
rich herzog
QUOTE (ajracer @ Feb 25 2005, 01:05 PM)
The rubbers appear to be in great shape, just really tight.
Regarding the actual force required to move the control
arm up or down is about 50 lbs...
Since it was mentioned that the bushing is "rubber
mounted to both the control arm AND the shaft that might
explain the reason it is so darn tight...
...My main reason for removing the arms
was to install the boxed arm reinforcement kit in
preparation for the V8 conversion.
yes - not just "rubber mounted" -- the inner pivot shaft is BONDED to the rubber bushing - which is BONDED to the trailing arm. IOW - it's a big torsion spring.
if you remove the molded-in rubber bush you will change the spring rate of the rear suspension, for which most people compensate by adding stiffer springs. i gather you already have stiffer springs on your shopping list with a V8 conversion...
but we can save you a bit more work - nowadays the boxed arm reinforcement is seen as a BAD thing. it adds unsprung weight, it adds thermal stresses to the trailing arm, and it adds stiffness to a part that doesn't needed it.
one of the jobs of the trailing arm is to bend in an impact to protect the suspension pickups in the tub. if you don't have an impact, you don't have stresses enough to require reinforcement.
look at it this way - the trailing arm is a fuse. you can put a bigger fuse in your house breaker box, but it just means that when you get an overload your fuse will survive at the cost of your house.
but - it's your car - do what you want...
ajracer   REAR Control Arm - HELP !   Feb 24 2005, 10:11 PM
bondo   Mine were like that. I think it's normal, or n...   Feb 24 2005, 10:51 PM
skline   Are they new? I know when I put my new rubber ones...   Feb 24 2005, 10:53 PM
Eric_Shea   The main thing to do at this point (while they...   Feb 25 2005, 09:26 AM
davep   Basically, the shaft and arm are both bonded to th...   Feb 25 2005, 10:47 AM
ajracer   Thanks Guys ! The rubbers appear to be in gre...   Feb 25 2005, 12:05 PM
davep   No, don't use penetrating fluid, that could ma...   Feb 25 2005, 12:13 PM
Joe Ricard   Some would say that if you are going to add more p...   Feb 25 2005, 12:21 PM
turbo914v8   Hey Allan buy my tub and you will get all that and...   Feb 25 2005, 12:25 PM
ArtechnikA   <...   Feb 25 2005, 01:00 PM
soloracer
- Lo-Fi Version Time is now: 16th July 2025 - 04:24 PM
