911 oil temp/pressure guage, need wiring help |
Trekkor |
Mar 2 2005, 11:47 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I have the guage in the car and the temp side is wired.
It's the pressure and idjit light that I need help with. New wires are run from the senders to the guage. What wire goes where? I have four wires. One off the idiot sender and three off the pressure sender. Help me help myself. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Attached image(s) |
Aaron Cox |
Mar 2 2005, 12:15 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
ok...all the gauges are labeled. they need 3 things. A switched + (i jumpered the existing one for the fuel gauge) and a Ground (once again jump/split the grounds taht are there) and the wire from the sender.
your green wire from the console tempgauge can be extended.....that goes to the remaining terminal on the temp gauge. now the other wire you magically ran from your oil press sender goes to the remaining terminal on that gauge. They are labeled you know + / sender symbol and G |
Lo-Fi Version | Time is now: 1st June 2024 - 01:12 PM |
