911 oil temp/pressure guage, need wiring help |
Trekkor |
Mar 2 2005, 11:47 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I have the guage in the car and the temp side is wired.
It's the pressure and idjit light that I need help with. New wires are run from the senders to the guage. What wire goes where? I have four wires. One off the idiot sender and three off the pressure sender. Help me help myself. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Attached image(s) |
lapuwali |
Mar 2 2005, 12:44 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
I've never seen a pressure sender that looked like that. I'd speculate that one of the wires is ground for the sender itself (as it it doesn't ground through the connection to the block, as usual). Where did you get that sender? Do you know if it will match the 911 gauge?
If you can't find any information on that sender, you would probably do yourself a favor by just buying the correct VDO sender for that gauge, which is a traditional 'can' type sender with two terminals on it. It's only $20-30. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:51 PM |
