Free Porn here, No----REALLY |
jwalters |
Mar 3 2005, 05:04 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Did I get your attention????? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Now maybe you can help me out----: (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) I posted this the other day and not a single stinking reply----where are all you guys when a fellow teenerphile is in need??? I feel so dissed---sniff---I need to be held,,,,sniff, sniff Now I am ducking for.... Hi guys. Been slow with my car---the weather has not been co-operating with me very much and have not got allot done--car will be going to painters in about 2-3 weeks-- So as now to shift focus on my engine build: The biggy is carb setup--herre are the motor stats: *1.7 stock bore and stroke *Webcam 86 *custom turbo exhaust *Garrett Tb-03 turbo, 8-10 psi boost nominal--never, ever beyond 12 *short intake manifolds *Weber 40's with dual blowthru induction ( Like on the buggies) *Stock 1.7 heads --no porting--just angle cuts on the seats. *max rpm of 6500--if it will do it....more like 6000 nominal *stock domed pistons--compression reset to 8.0:1??? Now my delimma with the webers: They are all stock, 28mm vents, 115 mains, 50 idles, 200 air correction, and F7 tubes. What would be the collective knowledge on setting up these carbs for a good baseline: Go to: larger vents? What size? 32-34mm? what would be a good main size to start with? keep the F7 tubes?? Idle jet change?? Air correction jet change??? What about those idf update kits I see--are they really any good??? I may as well as get started on this pig now while I am waiting for paint and reassembly. TIA--- (IMG:http://www.914world.com/bbs2/html/emoticons/hide.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/hide.gif) |
ArtechnikA |
Mar 3 2005, 06:06 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
i didn't think my reply would be helpful to you but as you seem to need it, here ya go:
"i have no fricken' clue." look - you're off the map here. buy yourself a good wideband A/F meter and book some time on a chassis dyno. you wanted the job of automotive test engineer, and you've got it. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:18 PM |
