Free Porn here, No----REALLY |
jwalters |
Mar 3 2005, 05:04 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Did I get your attention????? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Now maybe you can help me out----: (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) I posted this the other day and not a single stinking reply----where are all you guys when a fellow teenerphile is in need??? I feel so dissed---sniff---I need to be held,,,,sniff, sniff Now I am ducking for.... Hi guys. Been slow with my car---the weather has not been co-operating with me very much and have not got allot done--car will be going to painters in about 2-3 weeks-- So as now to shift focus on my engine build: The biggy is carb setup--herre are the motor stats: *1.7 stock bore and stroke *Webcam 86 *custom turbo exhaust *Garrett Tb-03 turbo, 8-10 psi boost nominal--never, ever beyond 12 *short intake manifolds *Weber 40's with dual blowthru induction ( Like on the buggies) *Stock 1.7 heads --no porting--just angle cuts on the seats. *max rpm of 6500--if it will do it....more like 6000 nominal *stock domed pistons--compression reset to 8.0:1??? Now my delimma with the webers: They are all stock, 28mm vents, 115 mains, 50 idles, 200 air correction, and F7 tubes. What would be the collective knowledge on setting up these carbs for a good baseline: Go to: larger vents? What size? 32-34mm? what would be a good main size to start with? keep the F7 tubes?? Idle jet change?? Air correction jet change??? What about those idf update kits I see--are they really any good??? I may as well as get started on this pig now while I am waiting for paint and reassembly. TIA--- (IMG:http://www.914world.com/bbs2/html/emoticons/hide.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/hide.gif) |
ChrisFoley |
Mar 3 2005, 07:12 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The heads are going to be your limiting factor for sure.
I say pull them and get a nice port job and SS valves. Up the valve sizes to 1.8L specs. Then you can go to 32mm vents. The jetting will have to be by trial and error, but I think 200 AC jets will be too big. I also think the F11 emulsion tubes are a better choice than the F7s. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:56 AM |
