Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
205/50/ZR15's R3S03's
I'm pushing. Help me turn in. Ran 25psi front and 27 psi rear. How low can I go? I'll loosen up the front bar as well. Workin' on tiars right now. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Thanks, KT |
drew365 |
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 ![]() |
Generally Hoosiers don't like to be run that low. I experimented with pressures from as low as 24# and found they would stick the best at 31# cold which is what they recommend in the pamphlet that comes with them from Tire Rack.
But that is on the track where I get them heated up after a lap. You're doing AX, you should be using the A series but I'm sure you know that. When I ran them as low as 24, 25 and 26# cold I felt like the side wall was starting to roll over. So, I don't know what to tell you for R tires on AX but I still don't think you want to be running that low. I would try 29# to 31# range ambient temperature. |
Lo-Fi Version | Time is now: 19th September 2025 - 01:44 PM |
