age old master cylinder question, I have both - new |
TravisNeff |
Mar 11 2005, 04:50 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I swapped suspensions between cars, and I have a brand new 19mm master cylinder and found that the silver car has a brand new 17mm master cylinder. Brakes are stock, metal master pads.
I know that the 19mm will not improve braking performance, and will have a shorter pedal travel (along with more effort) than the 17mm. That said, if you had either to choose from with stock brakes - what would you choose? |
lapuwali |
Mar 11 2005, 05:10 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
It's a feel issue. Some like one, some like the other. There's no right answer here. If you like the brakes as they are, leave them alone. If you want a firmer pedal, try the 19mm unit. All it takes is some time and brake fluid to do a swap.
Lo-Fi Version | Time is now: 3rd June 2024 - 04:45 AM |
