Stiffening the framework |
Rand |
Mar 11 2005, 07:54 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I'm looking into ideas to strengthen my car. Not a full cage, just a few tubes. I've read the classic threads and I'm in awe of the caliber of guys (like Brad, Jeroen, etc) we have offering help around here... hoping for your comments on this...
My goal is an aggressive street car that is strong enough for a V8 conversion. I'm looking for the simplest way to add some strength (with the least amount of added pieces). It's all about function and I don't need to be concerned with racing classifications and rules. I'm thinking the first stage is bracing from the rear shock tower to firewall, then inside firewall to frame rail, something like the red bars in this image: (IMG:http://www.4nets.com/baldwinpowersports/images/stronger1.gif) Is the firewall a strong enough part of the structure to use this way (if the tubes are just welded to their respective side of the firewall)? Or should the tubes go through the firewall, welded directly to each other at the top, and another down tube tied in (like the green)? |
r_towle |
Mar 11 2005, 08:28 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
you would be transfering a dynamic load to the middle of the long in the door frame...this area has been known to fail...
You need to either extend it forward or put in an inner long re-inforcing kit (sold in the resource area) A cross brace behind the firewall , in the engine bay, tying the two new tubes together would also be a good idea. The green tubes should be angled down more and attached at the bottom to the suspension console. Good luck. Rich |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:30 AM |
