Stiffening the framework |
Rand |
Mar 11 2005, 07:54 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I'm looking into ideas to strengthen my car. Not a full cage, just a few tubes. I've read the classic threads and I'm in awe of the caliber of guys (like Brad, Jeroen, etc) we have offering help around here... hoping for your comments on this...
My goal is an aggressive street car that is strong enough for a V8 conversion. I'm looking for the simplest way to add some strength (with the least amount of added pieces). It's all about function and I don't need to be concerned with racing classifications and rules. I'm thinking the first stage is bracing from the rear shock tower to firewall, then inside firewall to frame rail, something like the red bars in this image: (IMG:http://www.4nets.com/baldwinpowersports/images/stronger1.gif) Is the firewall a strong enough part of the structure to use this way (if the tubes are just welded to their respective side of the firewall)? Or should the tubes go through the firewall, welded directly to each other at the top, and another down tube tied in (like the green)? |
Brad Roberts |
Mar 11 2005, 08:37 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Hi Randy (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif)
You are on the right track... everyone above me is correct about the longs being weak. The first place I see them split is just north of the ebrake handle recess. The V8 cars *really* twist the chassis' with their torque. I like your tube placement.. the only thing I would add would be one of the "Engman" cabin/interior stiff kits. This will box the frame and give you a sturdy place to mount scab plates for your tubes. Another area that I rarely speak about: Just below the rear window all the way across the car. I use square tubing here and it is basically hidden below the engine lid. It helps tie the car together. B |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:13 AM |
