> 914-6 Weber 40IDA adjustment problems
hars914
post Mar 12 2005, 08:23 PM
I just rebuilt my carbs for my six. I got the car warmed up and started tuning them.
First when I turned the mixture screws on one of the carbs the idle did not change unless I just about turned them all the way in. The other carb did not change much
at all when I turned the in or out. When I tried to adjust the air correction screws on both carbs I could not get them to all read the same on the sync tool. I was geeting a lot of backfiring thru thru the carbs. What is my problem here???????
hars914
post Mar 14 2005, 06:26 AM
Thanks for the help.I will check for vacum leaks and I do have a pmo gauge and the
floats were fine.All the gaskets are new. All the jets are stock for weber 40's.I made sure all the passages were clean when I rebuilt them.All linkage was disconnected
when I made adjustments.I did notice when I had the sync gauge on one carb it
would balance fine at around 4 to 4.5 and the other carb would get one barrel to a maximum of 4.5 and the other 2 barrels I could not get any lower than 6 no matter what I did with the air corr. screws.
Anyway JP I will PM you for help.
- Lo-Fi Version Time is now: 15th July 2025 - 03:47 AM
