> 914-6 Weber 40IDA adjustment problems
hars914
post Mar 12 2005, 08:23 PM
I just rebuilt my carbs for my six. I got the car warmed up and started tuning them.
First when I turned the mixture screws on one of the carbs the idle did not change unless I just about turned them all the way in. The other carb did not change much
at all when I turned the in or out. When I tried to adjust the air correction screws on both carbs I could not get them to all read the same on the sync tool. I was geeting a lot of backfiring thru thru the carbs. What is my problem here???????
Thorshammer
post Mar 14 2005, 10:57 AM
All of these are good points, however I would like to mention the overall condition of the engine, the engine will act exactly as you are describing if the valves are tight. Please check your valve clearance and compression then tackle your carb problem if that is what it is.
Erik Madsen
- Lo-Fi Version Time is now: 15th July 2025 - 02:41 AM
