BPGREER |
Member ![]() ![]() Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 ![]() |
Well it looks like it may be time to tear my engine apart. McMark was kind enough to point out my lack of compression this weekend. It looks like I have about 110 lbs on 2 cylinders, and 120 on the other 2. The motor has 64,000 miles on it (original), but it did sit for 17 years in a garage by the ocean. A guess is that the cylinder walls have pitted. I am thinking about rebuilding the top end. I realize there are some who disagree with ever taking this approach, but being that the engine has relatively low miles I hope it will work out. If I do choose this method, what would you all suggest in the way of cylinders/pistons sets, etc. I am running the orig Djet, so would going with the 96mm setup still function properly? I'm not trying to stray too far from stock (or to spend too much $$$), but wouldn't mind a little extra power. Thanks for any advice.
Brian |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
yes, yes and yes.
higher compression (can) mean higher grade fuel. i run 9:1 on my engine and i run 91 gas. i'm sure i would get away with 89, but i've never tried. going to a 2056 with euro P&C will give you more HP, even with the stock D-Jet. you'll need to fiddle a little bit with a few components, like the MPS, but it has been done before. ask Geoff for advice, he's running a 2056 with stock D-Jet ... and Lyressa is running the same setup as well. as long as the heads turn out to be ok, a top end rebuild (new P&C) is easy and affordeable. if the heads are cracked, you'll have to fork out more $$$ for machine work. all in all, i vote for the top end rebuild with the 96mm euro P&C. same price, more HP! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Andy PS: did you find that vaccuum leak? |
Lo-Fi Version | Time is now: 11th July 2025 - 09:06 AM |
