BPGREER |
Member ![]() ![]() Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 ![]() |
Well it looks like it may be time to tear my engine apart. McMark was kind enough to point out my lack of compression this weekend. It looks like I have about 110 lbs on 2 cylinders, and 120 on the other 2. The motor has 64,000 miles on it (original), but it did sit for 17 years in a garage by the ocean. A guess is that the cylinder walls have pitted. I am thinking about rebuilding the top end. I realize there are some who disagree with ever taking this approach, but being that the engine has relatively low miles I hope it will work out. If I do choose this method, what would you all suggest in the way of cylinders/pistons sets, etc. I am running the orig Djet, so would going with the 96mm setup still function properly? I'm not trying to stray too far from stock (or to spend too much $$$), but wouldn't mind a little extra power. Thanks for any advice.
Brian |
BPGREER |
Are you running carbs or FI? I'm planning on maintaining my Djet setup. If you're running Djet, how much tweaking did it require to get it dialed in? Thanks. |
Lo-Fi Version | Time is now: 11th July 2025 - 10:14 AM |
