Alignment Spec Questions, another alignment thread |
John |
Mar 15 2005, 03:38 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I have a few questions that some of you smart people out there might be kind enough to answer for me.
I am wondering how you convert angular toe-in (per factory specs) to inches of toe-in. I could convert angles to inches if I knew where to measure. Is the toe-in measured at the rim, at the tread, at the sidewall? Or am I reading the chart from the factory manuals incorrectly? What are the "factory" settings for: Front Caster Front Camber Front Toe Rear Camber Rear Toe On another note, RIDE HEIGHT......... The front ride height is measured as the DIFFERENCE between the center of the torsion bar and the center of the wheel rim. How is the rear ride height supposed to be measured, and what is the 'spec'????? Thanks for replying. |
John |
Mar 15 2005, 11:01 PM
My questions started this weekend when I aligned the track car. I started out by lowering it to where my dad wanted it, and then corner balanced it and finally aligned it.
The car seems to be tail heavy. It is a 3.2 with a 915 trans. 9x16" wheels on all four corners Kuhmo Victoracers (245/45). 23mm torsion bars 21mm Front Sway bar 400# Rear Springs My percentages ended up as follows: LF = 20.4% RF = 17.7% LR = 32.6% RR = 29.2% As expected, the driver side is heavier (it included the driver), but the diagonals worked out fairly well. I aligned it with as much negative camber as possible and keeping both sides even. LF Camber -1.766 deg RF Camber -1.733 deg LF Caster 5.38 deg RF Caster 5.23 deg LF Toe 0.03 inches RF Toe 0.03 inches LF Inc Angle 13.26 deg RF Inc Angle 13.36 deg LF SAI 15.03 deg RF SAI 15.10 deg Total Toe 0.06 inches LR Camber -0.88 deg RR Camber -0.93 deg LR Toe 0.03 inches RR Toe 0.03 inches Total Toe 0.06 inches Thrust Angle 0.00 degrees I thought this information might help explain what i'm attempting to figure out. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:41 PM |
