iiibdsiil |
Needs Door Locks ![]() ![]() ![]() Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 ![]() |
I ran this by on a garage talk forum, so far my reply has been "I won't help you because I am not putting this website at stake if something happens" yada yada yada.
Hopefully someone here will answer my questions. Yes, I know PVC isn't recommended, etc. Start Thread: Okay, so I am going to run 1 1/4" PVC line. Yes, I chose PVC because I have heard from a few people locally that it is that much easier, cheaper, and it will work fine. People that have done it and used it for many years. I am still kinda skeptical, but these people I trust. Now, I have a couple questions. 1. I am going to run 50 feet from one corner, and from that same corner, 20 feet the other way. I think I read somewhere that with a bigger feed (1.25") that you will gain volume, but lose pressure, is that correct? I will be running 125ish PSI at my main regulator, which will be between the tank and where the PVC will start. Also, my 50 foot and 20 foot feeds will be 11 feet high, thus needing to drop 7 feet or so, so that is going to be more volume. I will have a total of 5 drops. Rather have more than I need then kick myself later. I know you like pictures so... (IMG:http://www.lockeddoorracing.com/airline/DSC00916%20(Small).JPG) Click here to see larger (5.0 megapixel) version That is the area that I plan on doing the lines at. The wall that is on the right will be my 50 foot feed. And then the wall that the electrical is on will be my 20 foot or so lead. 2. How do I get around this little obstacle? I would rather not have to square around it because I think that would hurt air flow? Maybe I can get something that is more circular? Or will it not matter? Picture... (IMG:http://www.lockeddoorracing.com/airline/DSC00917%20(Small).JPG) Click here to see larger (5.0 megapixel) version I will only need to go over the one electrical conduit there, as that light is 10 feet high, and the feed will be at 11 feet. Also, I am probably going to run the feed that goes from the compressor and up to the 11 foot mark directly in the corner, if I can find the T I would need to make this happen, if not, I will run it a couple inches in on the long wall. |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,008 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
I had PVC air lines in my body shop with 6 monkeys using them all day. I had them for 15 years. We had the the "T" fittings fail probably 6 times. I used 3/4" lines throughout a 4000 sf building. One precaution. When the plastic fails they shock the whole line hard. This caused other fittings to crack as well. I second the shutdown suggestion over night. BTW: I recall the PVC was rated for 400 psi at 80 deg far.
Lo-Fi Version | Time is now: 4th July 2025 - 03:26 AM |
