Alignment Spec Questions, another alignment thread |
John |
Mar 15 2005, 03:38 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I have a few questions that some of you smart people out there might be kind enough to answer for me.
I am wondering how you convert angular toe-in (per factory specs) to inches of toe-in. I could convert angles to inches if I knew where to measure. Is the toe-in measured at the rim, at the tread, at the sidewall? Or am I reading the chart from the factory manuals incorrectly? What are the "factory" settings for: Front Caster Front Camber Front Toe Rear Camber Rear Toe On another note, RIDE HEIGHT......... The front ride height is measured as the DIFFERENCE between the center of the torsion bar and the center of the wheel rim. How is the rear ride height supposed to be measured, and what is the 'spec'????? Thanks for replying. |
John |
Mar 16 2005, 12:40 AM
Thanks J P
But is it 15" or is it 7.5"??? |
Lo-Fi Version | Time is now: 1st June 2024 - 07:05 PM |
