Headlights are frustrating me, Just want them to work correctly |
Rhodes71/914 |
Mar 16 2005, 12:07 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
I've tried to work this out, I've done searches, but i'm still stuck.
Headlights work fine on low-beam. Click to high-beam and nothing. I can hear clicking at the relay which has been switched out and I don't think is the problem. Fuses are all good. Indicator light on the speed-o only come on when just the parking lights are on (knob pulled out one click} Could this be the headlights themselves? or do i just have some f-ed up wiring. Things look pretty normal at the fuse board. |
Dave_Darling |
Mar 17 2005, 12:11 PM
You remove the headlight switch by unscrewing the knob, then unscrewing the "escutcheon" (basically a nut with no flats but that has two little slots in it to turn it with) and pulling it out forward (toward the front of the car) into the dash. I used a little flat-head screwdriver in the slots to push the escutcheon in the "loosen" direction to get it started, then spun it off by hand.
I strongly recommend doing the checks for voltage. If nothing else, check at the high-beam fuses! You can also do a resistance check from the fuse to ground with the lights off; it should show about (60W/14V) 4.5 ohms resistance or a bit more. That will check the path from the fuse to the light bulb to ground, at least for small currents. --DD |
Lo-Fi Version | Time is now: 10th June 2024 - 09:47 AM |
