> stupid human questions, 12v => 110v => 12v
machina
post Mar 18 2005, 12:58 PM
Haven't had a problem with the battery running down yet but...
if I wanted to give a quick charge at the track, could I...
run an inverter in the truck to power a small 10 amp charger, to boost the battery between runs?
Will it run my truck battery down in a 1/2 hour? How big of an inverter will I need to run the charger? I've checked different brands specs but they don't seem to tell what the power consumption is.
lapuwali
post Mar 18 2005, 01:32 PM
Not another one!
You don't even need the diode. The alternator will basically just be charging both batteries. I'd arrange a quick-disconnect system using the large charging connectors you can find from Pegasus and others. It's not cheap, but it's MUCH less likely to result in an accidental short caused by someone in a hurry. Just attach one quick disconnect to the battery in the truck, and another to the 914. No need for an inverter at all.
synthesisdv   stupid human questions   Mar 18 2005, 12:58 PM
ArtechnikA     Mar 18 2005, 01:10 PM
scott thacher   sorry tony, its 10 amps at 12 volts not 120 so 10...   Mar 18 2005, 01:12 PM
TonyAKAVW
  Mar 18 2005, 01:15 PM
synthesisdv
  Mar 18 2005, 01:17 PM
bd1308   why dont you just keep the truck running, put a hu...   Mar 18 2005, 01:19 PM
lapuwali   You don't even need the diode. The alternator...   Mar 18 2005, 01:32 PM
bd1308   ...   Mar 18 2005, 01:37 PM
davep   I'm with James here. The best solution is basi...   Mar 18 2005, 01:41 PM
john rogers   Here's a great excuse for trying something new...   Mar 18 2005, 01:41 PM
synthesisdv   already got the plug in the car. have matching pl...   Mar 18 2005, 01:42 PM
synthesisdv     Mar 18 2005, 01:44 PM
davep   That being the case, get a spare battery and some ...   Mar 18 2005, 01:52 PM
synthesisdv     Mar 18 2005, 01:55 PM
Brando   I think it's time to incorporate this into a v...   Mar 18 2005, 01:56 PM
ArtechnikA     Mar 18 2005, 02:02 PM
- Lo-Fi Version Time is now: 8th July 2025 - 08:42 PM
