Yoei66 |
My ride ![]() ![]() Group: Members Posts: 168 Joined: 28-February 05 From: Portland, OR Member No.: 3,682 ![]() |
I acquired some new hoses, connections, nozzles, ect lately for my original pneumatic powered windshield wash
system. I could never get the system to work strong after the PO caked the spray nozzles with multiple waxing, and leaky hose between the tire and the wash tank. It would only spray out of two of the four nozzles for a few hours, before the tire lost pressure, but still worked. Yesterday I put a fresh hose between the tire and tank, and replaced the spray nozzles. Now I have a new problem. Once the tank is pressurized to 42psi the system will spray for about 1/2 second then it stops working. The tank is still pressurized, and I detached the hoses from the spray nozzles, still no spray. Every time I drain the pressure from the tank, and re-pressurize I get one interval of 1/2 second spray, then nothing. I took the tire hose and hooked the system up backwards. I successfully blew bubbles in the wash tank when pulling on the wash wand with this attempt. I thought this would clear the system with a backflush. I them hooked the system back up normal, except for the spray nozzle hoses jest hanging free to eliminate the new nozzles from the test I still get the same 1/2 second of wash, requiring a pressure drain reset for another 1/2 second. Is this indicating a bad steering column control. I’m considering rigging up an electric pump system, but am willing to try a few more things to get the original, quirky system working again. |
ChrisFix |
Member ![]() ![]() Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 ![]() |
I just finished replacing all the hoses on me washer system yesterday. There are check valves below each of the spary nozzles that may be bad on yours. If you have them, try bypassing to see what happens. The valve switch in the steering column is just a manual valve that has a small pin witch the wiper switch lever presses against when you pull it forward. I can't think that it could malfunction in the manner you describe, but if you pull the steering wheel and the switches, you could test it easily enough. The system runs a pressurized tube from the bottom of the washer bottle to one side of the switch in the steering column. The other side of the switch is un-pressurized and runs to the nozzles. Pretty simple. There is supposed to be a pressure control such that it won't work below 29 PSI (I think) so that you don't run down the spare. If that wasn't working correctly, it could conceivably cause the problem you describe.
If you end up taking the steering wheel off and the switches out, and haven't done this before, let me know and I can fill you in on the secrects that only doing it will teach you. |
Lo-Fi Version | Time is now: 8th July 2025 - 11:34 PM |
