Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Hopefully this makes sense to someone besides me (IMG:style_emoticons/default/smile.gif)
Pictured below is a bad representation of the trailing arm shaft and the inner trailing arm ear. When adjusting the alignment on the trailing arm which side is tightend down first? (mount or inner ear) I cannot see how the face of the trailing arm shaft and inner ear are perfectly flat against each other, if the outer mount is moved and tightened so that it mates perfectly flat with the shaft as well something has to give. The 3° in the picture is just number I came up with...but ideally, one would want 0° on both planes where the mounts mate with the shaft.......with the current design, both mating surfaces can be perfectly flat with one another, but the alignment more than likely will not be correct??? IMHO Opinons?? / Flames?? |
Lo-Fi Version | Time is now: 3rd July 2025 - 12:06 PM |
