Fresh Air Fan, Anyway to Access To Test? |
ChrisFix |
Mar 26 2005, 07:40 PM
Member Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 |
Is there anyway to get to a connector on the ventilation fan to apply 12V and determine if the fan is bad? The control panel fan indicator lights up (which runs off the same relay and fuse), but the fan doesn't run. I would like to determine if the fan is good or bad before removing the tank to get at it and was wondering if there is a way to do this.
Thanks! |
McMark |
Mar 26 2005, 10:55 PM
Okay, I read the wiring diagrams. 12v goes into the motor and grounds through one of the three wires. To test the motor, pull the three wires (arrowed) and connect each one to ground with a jumper wire. The door stay is usually a decent ground. Your motor should run three different speeds.
Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 07:57 PM |
