> L-jet running rich
Ctrout
post Mar 26 2005, 06:09 PM
I know that everyone here has D-jet but does anyone know of any L-jet gurus anywhere? My car has smelled like it runs rich since I got it. While doing some exhaust work this morning, it was confirmed by the black soot everywhere. I thought I read somewhere that these cars ran rich from the showroom floor. I have backed the idle adjust all the way out with no apparent change in the richness of the mixture. It did change the RPM to a point though. I read in one thread something about coming in from working on the car and smelling like I had been standing next to a diesel campfire. That's me!
Cap'n Krusty
post Mar 27 2005, 11:21 AM
Cap'n Krusty
A rich condition, beyond the scope of the idle mixture adjustment is ALMOST ALWAYS a bad airbox. Vacuum leaks may make it fail to run, but they won't make it rich. "Fallse air" going past the valve cover gaskets, the rectangular gasket on the filler box, the o-rings in the cap, all will prevent the car from starting, as the AFM isn't reading the air. A messed with airbox is usually a bad airbox. A reman airbox is usually a bad airbox someone has attempted to fix. Generally, what goes wrong with them, a sticking flap, doesn't get properly addressed in the reman process. Belly up to the bar and buy a new one! AFTER you've tested everything else, that is. In general, L-jet/Digijet FPRs go bad a lot, although the ones on 914s are an exception. Check for a good, even voltage supply to the ECU, check ALL THE GROUNDS, the valves, the dwell and timing, and the filters. The double relay won't affect the mixture, only the ability to run at all.
Hmm. Digijet ........... Anyone here ever given any thought to running Wasserboxer Dijijet on a 914? Seems to me it would be a drop-in ...................... The Cap'n
Ctrout   L-jet running rich   Mar 26 2005, 06:09 PM
scott thacher   well i know a fair amount about the ljet drove one...   Mar 26 2005, 07:15 PM
Brando   If you've ever adjusted the mixture/richness o...   Mar 26 2005, 08:04 PM
scott thacher   brando i will disagree with you on this dont open ...   Mar 26 2005, 08:39 PM
Brando   I will disagree with us both, Scott, if it makes y...   Mar 26 2005, 08:42 PM
scott thacher   sorry brando but porsche put the screw there for a...   Mar 26 2005, 08:47 PM
scott thacher   okay here is the page from the l jet trouble shoo...   Mar 26 2005, 08:56 PM
Brando   Yes Scott, I understand. The point I was trying to...   Mar 26 2005, 09:07 PM
scott thacher   i would say if he is rich on every cylinder i woul...   Mar 26 2005, 09:17 PM
Reiche   Did you check fuel pressure? Unlike D-jet, the fu...   Mar 26 2005, 09:24 PM
Ctrout   Thanks for all the replies. I'll go through t...   Mar 26 2005, 11:27 PM
scott thacher   okay the two screws are as follows: idle screw is...   Mar 26 2005, 11:45 PM
Reiche     Mar 27 2005, 01:07 AM
ClayPerrine   I agree with the statement .... DO NOT OPEN THE AI...   Mar 27 2005, 10:30 AM
rhodyguy   all the yelling aside, this is a great L-jet threa...   Mar 27 2005, 10:43 AM
scott thacher   ...   Mar 27 2005, 10:48 AM
rhodyguy   but it could contribute to a lean condition? the s...   Mar 27 2005, 10:58 AM
Cap'n Krusty   A rich condition, beyond the scope of the idle mix...   Mar 27 2005, 11:21 AM
rhodyguy   the CIS-E from a jetta, golf, etc? i think ed morr...   Mar 27 2005, 11:54 AM
Mark Henry   http://www.914world.com/bbs2/htm...   Mar 27 2005, 01:34 PM
Cap'n Krusty   ...   Mar 27 2005, 02:30 PM
Reiche   I agree with jwalters, but... I would mess with ...   Mar 27 2005, 02:44 PM
jwalters   Dude--do you know how time consuming it would be t...   Mar 27 2005, 05:55 PM
Rotten Robby   Wow... L Jet sure wakes people up and gets them vo...   Mar 27 2005, 06:46 PM
Reiche   ...   Mar 27 2005, 06:52 PM
jwalters     Mar 27 2005, 07:08 PM
- Lo-Fi Version Time is now: 6th July 2025 - 04:13 PM
