Breaking stuff... over and over, Victory! (mostly) |
Lawrence |
Jun 17 2003, 01:44 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
This job gets worse and worse. I think disassembling with a sawzall would be easier.
- I broke the two hard brake lines on the left side. - I broke the tie rod end on the left side. - Steel sleeve on the drop link bushing was frozen to the thru-bolt. I broke the U-tab on the A-arm trying to free it up. All the sway bar bolts on the left side are frozen solid. - I tore the ball joint boot, and dented the metal beneath. The strut still doesn't want to come off. I may go rent a pickle tool. - Somehow, I tore the front wheel bearing seal. I'm barely into the right side, and it's 86 degrees, no shade. |
Lawrence |
Jun 18 2003, 07:37 AM
21 mm.
Lo-Fi Version | Time is now: 2nd June 2024 - 08:33 PM |
