DIE F.I.!!!!, Tired of fiddling with no results |
McMark |
Jun 18 2003, 05:58 PM
My fuel injection will most likely come off my daily driver in the next few months. I hate to switch to carbs, but I'm so tired of fiddling with the FI and not getting any results.
Right now, my biggest problem is that my car won't idle when it's hot. It runs great when it's cold. But once it's reached operating temp it won't idle. I'm thinking that it's not firing on all cylinders once it gets warm. Today I had a lot of errands to run and so at first it was the usual heel-toe at a stop light to keep the rpms up. By the time I was heading home I had to rev to 3000 rpms to get going at all. It's just ridiculous to have all these 30 year old FI parts, none of which cam be trusted to be working correctly. I have brand new TPS, Head Sensor (NAPA brand), and my MPS was tested and okayed by Jeff B. I checked my Trigger Points on the oscilloscope and they're firing as normal. I adjusted my valves this morning and they were good enough before I changed anything, and now they're even closer. If I could fix the FI without spending $1000 on parts I would do it, but I don't think that's realistic. Grrrr, I'm just fed up |
Bleyseng |
Jun 18 2003, 06:13 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
First of all, make sure the timing is set right-to 27degrees before top dead center at 3500rpms. I think your timing is off.
Get the right CHT After you do these, then set the idle mix hot either with a CO meter or by ear. The idle must be set when the engine is hot or rather operating temp. Otherwise, you will be chasing the idle setting forever. When cold the idle is high (1500-1800) rpms by the AAR valve. When the engine is warming up it can hunt alittle bit. When it is hot, the idle should be steady at 900-1000 rpms. IF you adjust it when its cold or warm you have problems usually because you set it too rich. When the engine is hot it "bogs" at idle from the over rich mixture. These are the 3 things I see with idle problems beside vacuum leaks. 1. Mis timed 2. Wrong Parts- CHT or vacuum hoses hooked up wrong 3. Set when cold to warm engine temp so Best I can recommend now Geoff (IMG:style_emoticons/default/Yack.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:16 AM |
